I've read this whole thread and have gotten some great info, so thank you for that. My question is two-fold, I'm going to add a MotoFab 1.5" leveling kit to the front. My 2015 Silverado has the stock 17 inch wheels on it. With this leveling kit, and what are the largest size tires I can run with that leveling kit and keeping the stock 17 inch wheels? I've seen a lot of answers for the 18 inch wheel, just nothing for the 17 inch wheels.
Clearance shot of 285/70-17 Terra Grappler G2's. Stock 17" rims. I'm leveled in the front. I've never had any rubbing even flexed in the mountains. This is without holding back the fender liner at all.
Edited by dannynoonan
I talked with rough country yesterday for everyone that's running a 2" level and 17s. They say you can safely run a 17x9 with a backspace of 5.5-6.0 and an offset of +12-+25 And 285/70/17 Tires.
The tires are Atturo Trail Blade 275/65/18 and the wheels are Strada Off Road Monster Wheels 18x9 with a 0 offset, The tires stick about 1/2" out of the fenders.
Have any more pics? Down the side ? I really like how the tires stick out just a little its perfect
If you go with the front 2.5" level only, it will be completely level or very close.
If you want to see what your truck would look like with a 2.5" front level only and 275/70/18 on those wheels, just look at my gallery as it is exactly what I'm running right now.
Can you show me some pics of your ride? I'm new to this and you said view gallery to someone else and I can't find one
Is there enough stud length to run a 1/2" spacer behind the factory wheels? I'm looking at the readylift hub centric spacers for the front. It says they are required for thier 4" kit when using factory wheels, so I'm guessing they will work.
I'll be running 295/55/20 toyo extreme AT2s with stock All Terrain wheels and I know they will rub the a-arms.
This was it with the 2.5" front level and before I installed the 1.5" body lift. No blocks in the rear.
This is what it looks like with just a 1.5" spacer. Notice how it sits lower in the front.
Edited by surebuttercringe
**update** just order them.....Rancho has there 60th anniversary rebate get a $126 back on a visa gift card when order front and rears....
Ordered mine on Sunday morning will be delivered tomorrow. I'll be installing on Saturday. I think I got the wrong rear part number I ordered RS9000XL Part # RANRS999198. I think it may need to be Part # RANRS999197????
No rs999198 is the right part number. If you go to rancho website and look in the catalog it fits 2007-2013 trucks with stock height in rear which fit 2014 trucks.
Yup, just pulled up the PDF rs999198 is correct. Thank you!
Now I'm regretting getting the 1.5 instead of the 2 inch...
Easy fix. Just do what I did. Order a 1" spacer from eBay that mints to the lower part of the strut, in between it and the lower control arm. That way, you don't have to pull the entire strut assembly out again.
As long as I can fit 285/75-17 tires on my stock wheels I'll just use the 1.5...
I have spent 3 days reading 179 pages I think I've finally decided on a 2.5 rough country front only with stock rear block, I want to run 18" fuel maverick rims with Toyo Open Country MT and I want my tires to be wide and to stick out just a little with NO RUB what size and offset should I run? I have a few sizes in mind below
275/65/18
275/70/18
285/65/18 <<
Thanks in advance
2014 Silverado 4x4
Edited by cameronfaber
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,127 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
