I drive 66 miles per day with 80% of that being interstate driving. I fill up once a week. I would love to level but I am worried about losing mpg. Any thoughts on how to avoid losing mpg?
Leveling won't lose but maybe 1 MPG on the highway. I have had a level since the day I got the truck and still see up to 21-23 MPG during the summer and 17-19 during the winter.
Don't put bigger/heavier wheels and tires on. A level is fine, but it's the wheels tires that kill mpg.
2014 Sierra
20x9 Dropstar 645MB +18 offset
295/55R20 Nitto Trail Grappler
2.25 Pro Comp level kit
Absolutely in love with my truck and can't stop looking at it!
Sweet ride man!!! I'll have my leveling kit and 295s in about 2 weeks!
Rough Country 2inch level up front . Zone add a leaf out back 275/65r20 Duratracs.
How do you find the change in ride characteristics? Is the rear much stiffer?
anyone know why my steering wheel clicks when im turning the steering wheel left or right ?
I can only hear it when im stopped in drive or reverse. Not all the time but half the time.
I just got my 2.5 RC level put on.
Any info , i would greatly appreciate.
Anyone know why RC has this kind of block for the rear? http://www.roughcountry.com/gm-leveling-lift-kit-1305-10.html
Zone has tappered 2" blocks like this http://www.zoneoffroad.ca/suspension-parts/leaf-spring-components/lift-blocks-2-tapered-2-3-blocks-3-4-pin-part-number-zonu3022/
I decided to start with a 2" level up front. I just want to see what my options are for the rear if need be.
Thanks!
Edited by Dropsix
What size tires are you running with your level?
Stock 20 chrome rims w/ stock 275/55/20 Goodyear SRA
I'm very disappointed in the plastic skid plates on these trucks. driving on a ranch road i had something come up and knock a good crack/hole in my skid plate. anybody know where to find a decent metal skid plate it looks like they don't even make them yet
It probably is stiffer but I don't notice. I think it handles better and you can actually put some weight in the rear without it sagging.
on my 2010 gmc all terrain 1500 I ran an add a leaf and a hellwig helper spring.
For those of you with 1.5-2" of level, what max diameter tire are you able to clear? I'm thinking 34" would be the max limit with trimming, 33 with little to no trimming, and 32.5 with no trimming.
As for thickness i think with stock offset 11.5 is going to be max.
I found 295/60/20 Trail Graps for 260$ a tire new. Incredible price honestly.
34's did not require trimming, at least for me. See my signature block and photo gallery for more details. Smartest solution is to have your shop do a test fit before committing the $$, that's what Discount Tire did for me.
2014 Sierra
Looks really nice. any rubbing?
Thank you sir! I haven't gotten it to rub yet, so I'm thinking I'm in the clear on the normal driving.
I just took mine to the dealer for this. I brought my iPad in and played the video another fella posted in the problem section.
I told him I think either something has come loose right where the steering wheel attaches to the column like a piece of plastic or something.
He took off the wheel and said that one of the screws had backed out and actually rubbed a groove into the base of the mounting surface of the wheel. He put locktite on the screws and re fastened. Thought problem was solved...
But as I pulled out of the parking space from the dealer it sure as shit was back...
Almost flipped out but just accepted the fact that this truck just has a clicking steering wheel and that's that.
I don't have the mental health left to pick apart this truck after trading in my brand new lemon Ram 1500 for this truck which is my dream truck. This truck has to many good things to make a big deal out of a click here or a rattle there.
But if you want to start your battle, I would start looking there.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
