34's did not require trimming, at least for me. See my signature block and photo gallery for more details. Smartest solution is to have your shop do a test fit before committing the $$, that's what Discount Tire did for me.
Thanks for the clarification. I've since decided to get 17" rims which will allow 285/70/17 or 295/70/17.
33x11.5x17 or 33.6x12x17. Either should fit. Funny 285/70/17 toyo Mts are 350$ RTs are 317$ and the 295/70/17 Mts are 318$. Weird.
All about what sizes are popular. If it's a more common size to be purchased it'll be cheaper. At one point I was looking at a 295/60/20 tire and it was like $60 more per tire than a 295/65/20
i run 285/75/17 and doesn't rub at all, i could probably even go to a 305/70/17 and be ok but i just got a 2.25 kit put on the front
Hey guys, I've read over all the pages and got a lot of good insight. Here is my plan to level my truck (2015 GMC Sierra 1500 Z71 Crew Cab Standard Bed.)
2.25 inch Ready Lift on the front
Blocks for the rear for an inch increase to keep some rake
I can't decide on what size tire to get...285/60R20 or 275/65R20, on factory 20s.
When I get this completed, I'll post pictures. Thanks for any input.
I'm looking at running 285/75r17's. What is the offset on your wheels? Got pics?
The only tire that comes in 285-60-20 is the Goodyear Duratrac. 275-65 opens your options up some and most mfg's make this size. In my opinion 285-60-20 is the perfect tire size and I am not sure why more manufacturers haven't caught on. I have no experience with the Duratrac but have heard great things. I have mine leveled and have Toyo Open Country AT2's on mine in the 275-60-20 which are too small in my opinion so I am looking at 295-55-20 or 275-65-20 as well.
Edited by hotrodz37
I agree 285/60/20 is perfect, but as you said noone makes it. So long 20s lol. Everyone has 17 sizes, Mickey Thompson, Toyo, Nitto, BFG, Goodyear, all of them almost have 285/70/17, actually i think all of them. I know not all have 295/70/17. 285/60/20 would work perfectly but if your wanting a 33" tire with no rub and are stuck to 295/55/20 or 305/55/20 you pretty much need spacers or a new rim for offset it seems. Which sucks.
It probably is stiffer but I don't notice. I think it handles better and you can actually put some weight in the rear without it sagging.
on my 2010 gmc all terrain 1500 I ran an add a leaf and a hellwig helper spring.
I'm on the fence on whether to go with a 2" block or adding a spring. I won't be doing it super often but I'll be carrying my 4 wheeler in the bed a few times over the summer. But when I'm not carrying the ATV, I'd like a smooth ride still.
Have you considered air bags? I know they won't affect the ride when they are deflated and can be adjusted. I don't tow often but when I do it pulls me way down so I plan to put airbags eventually.
Airbags sound expensive.
I'd want to keep it on the cheap side.
Airbags are cheap if you don't mind filling them manually. It's not quite as convenient but you get all the function.
I've read this whole thread and have gotten some great info, so thank you for that. My question is two-fold, I'm going to add a MotoFab 1.5" leveling kit to the front. My 2015 Silverado has the stock 17 inch wheels on it. With this leveling kit, and what are the largest size tires I can run with that leveling kit and keeping the stock 17 inch wheels? I've seen a lot of answers for the 18 inch wheel, just nothing for the 17 inch wheels.
Edited by Buckeye920
I run a 285-75-17 and it doesnt rub and that was without a level kit with a +12 offset wheel so i would say that this size would be the biggest IMHO. you would be safe really safe with a 285/70
I'll look into it
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
