I'm trying to play it safe being that there's only 2 inches added up front and 0 offset.
Nitto tech specs:
275/70-18= 33.62x11.10
285/65-18= 32.83x11.93
285/75-18= 35.08x11.26
I have the 275/70/18 on stock rims. I went with the Hankook Dynapro. So far so good. No rubbing. We got a ton of snow and they have done really well. They look fairly aggressive but not too noisy. I'm pretty happy with them. I did measure my truck after installing the Bilsteins. 38 to front fender and 38.25 to rear. It's damn near level. I'm running lower air pressure right now with the foot of snow we have on the ground. It may come up a little more once I start playing with more air pressure. The tire dealer only put 37 lbs in the tires and I think I'll take them up to 45 and see how it rides once the roads clear up.
Turned to full lock, how much clearance for a larger tire is there? To the sway bar and bumper corner? If you could look please. Thanks.
After the 18" tire size dilemma I've decided to go down to a 17" tire and settled on cooper St maxx's in 295/70/17. Little over 11.5" wide and a little over 33" tall, which is what I was aiming for. Might I add, Mr. Wheel Deal was the best prices I could find anywhere, online or local by over $500
I probably missed the 18 in rim dilemma but what backspacing are you using on the 17s, and what was the issue with the 18s? Thanks
I have 275/65's. No rubbing just need a cable tie the inner liner back. Both sides 3 mins. each
spx what liner are you talking about? are you running stock tires? Im doing the 2.5" RC level and going to be running mayhem wheels at +18 offset and tera grapplers 275/65/20.
The issue with 18s is the tire sizes available 275/70/18 just isnt quite big enough and 295/70/18 is too tall.
17s solves the problem by going with 295/70/17 you get the width and a good height.
the plan is to go with 17x9 +0, today. That plan may change by supper time lol
I got my 285/65-18 32.83/11.93 Nitto Trails mounted on my 18x9 0 offset today! Haven't encountered any rub so far!
Rough Country 2inch level up front . Zone add a leaf out back 275/65r20 Duratracs. bca21d71-9b9f-4277-a7d2-6aaaf1ec92aa.jpgIMG_20150221_104315.jpg
u have just 2" RC kit in the front? Does that size tire rub at full lock?
Sent from my iPhone
using Tapatalk
and yes it rides awesome. I had RC leveling kit before. Now rides awesome. U get what u pay for
Sent from my iPhone
using Tapatalk
How much did you find them for ? just curious
i paid a company to do everything. It cost total I think around $850
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
Oh ok, I'm running 285/75/17 cooper a/t tires and xd hoss rims but I'm not feeling the look anymore but i don't want to go to a larger tire because gas mileage will drop even more.
I want a little more offset than the xd's i have
whats the offset?
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
yes it rubs the on the fender liner, but if you wire tie the liner back you can get plenty of clearance. even the people doing the 2.5 kit have to do this to fit this tire.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 414 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
