Why would the 2015 z71 be different?
It isn't any different. I've done about 8 trucks of this gen and never had an issue or had to undo a ball joint for any bottom spacer. Just got to make sure both wheels are off and both sway bar links are loosened off all the way.
For anyone interested in 5100's they do compress your coil more and it will cause premature wear of your coils. I had them on my old truck and prior to selling it I put new coils on. My coils I had been using with 5100's were over an inch shorter than the new coils. This is why down the road I will most likely go with rancho quick lifts and a block in the rear.
Think about that statement for a while....
Yes, the springs are compressed more...but only when the shock is completely extended, like when you have it out of the truck. Yes, then the spring perch is higher and the length of the shock is the same, thereby compressing the spring more.
When the truck is being supported by the spring/shock assembly, the weight of the truck is resting on the spring and the "pre-load" of the spring has no bearing on how much the spring is compressed. Only the weight on that corner of the truck matters. The reason that is true is because the spring is not "pre-loaded" enough, at the full shock extension with a 5100, to raise the spring force above the weight on that corner of the truck.
Regarding your new springs being longer...it is not due to the 5100.
I'm not doing a very good job of explaining this. I'll give it a better try here.
If we said the one corner of the truck placed, say 1000 lbs of force on the coilover assembly on a stock truck, measured at the base of the spring perch, with the truck resting on the ground, in a normal position.
If we said the stock spring was compressed in the stock shock assembly with 200lbs of force (pre-load) in the fully extended length, out of the truck, and the assembly was installed, the 1000lbs on the corner of the truck resting on it....the spring compressed to say 10" in length. ... 1000lbs of force measured at the spring perch, all stock.
Next, we move the spring perch up, say 1" higher on the shock body. In order to assemble the spring on the fully extended shock, we have to compress the spring 1" more. That puts more pre-load on the spring, in the fully extended length. But, when measured, the pre-load pressure on the spring perch is still less than the 1000 lbs of force as when installed...say 300lbs. When we install the coilover assembly, the force on the spring perch goes right to 1000 lbs as before, because the weight of the truck is unchanged. The spring will be the same 10" in compressed length.
With our shocks/springs in these trucks, the pre-load never approaches the forces of an installed coilover with weight on the shock/spring, regardless of OEM, 5100, or other make.
Edited by spurshot
All you have to do is loosen the sway bar bolts. You will be able to pry the control arm down enough. I did my RCX 2" this week and it was pretty easy. No need to touch ball joint, tie rod or upper strut bolts. If you undo both sides before you attempt to install the blocks that will help as the sway bar is connecting both lower control arms.
Love the look of your truck BTW. They have to be the best factory wheels GM has ever come up with.
I agree. I had 1 1/2" of lift (3/4" thick block) under my shocks. Unload both front wheels off the weight of the truck and loosen the sway bar. Pry down on the A arms. The length of the bolts will be critical. Too long and they will hit the axle (4x4). There's not much room in there.
Installed a Rough Country 2.5 front and rear blocks last night, under the guidance of another member and a buddy (his level kit will be installed soon) It's at the alignment shop getting aligned now. Pictures will follow later when weather gets better.
before measurements: front 36.5, rear 38.75
after measurements: front 39, rear 39.75
stock 275/55R20s
stock 275/55R20s
I am highly interested in this one. Pics pics pics!
Here's my leveling kit!
I hope to do my install tomorrow, but I ordered the 2.5" and decided to just use the 2" spacer no top spacer I believe, just to leave a little rack.
Just loosen or remove the whole endlink? Also what to torque back too?
Just wanted to let you guys know for those considering 35s...
They fit on factory 20's with minor wheel well insert trimming. It was worth it to me, so I did it. Very happy with the way it turned out.
I still rub slightly in reverse at full lock, I could probably remedy that with some additional trimming but I'm not sure I care at the moment.
I'll upload pics later for anyone who wants to see.
Setup:
2014 Sierra SLT 4x4
Pro Comp 2.25 leveling kit
Toyo Open Country M/T 35x12.5xR20
I'm still on the fence on getting a bigger lift. Not sure if I want to void any warranties just yet.
I finally got my wheels and tires on with my 2.5" leveling kit. Tires are 275/65-20
Sorry for thread jacking, but what guard is this?
I keep flip flopping on this decision but I think I'll do what you did, but leave out the .5" spacer up top and then go with 275/60/20 BFG K02's.
I hope this will make me happy and not squat the rear too much when I load my ATV.
Looks good and thanks for the pics! ANy change in mileage so far with just the level?
Edited by Dropsix
I plan to do this over the weekend, and just do the 2" front portion and then add 275/60/20 Cooper AT3s
Setup:
2014 Sierra SLT 4x4
Yes please I want to see pics of this! Want this setup, but not sure if it will work.
if it does squat too much, and if you are willing to get them, then you could add some air bags to get rid of the sag when towing
No rear block?
I know nothing about air bags yet. I have to look into it
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
