Remember I did 275/60/20s to keep in a 4ply tire and weight done only added 5lbs a tire
I just ordered that z71 emblem
Part#23465289 40 per
My Current Setup,2014 Silverado 2LT Z71,RCX 2.5 Level Kit,NittoTerra 33x12.50R20Lt's,Fuel - Octane D509 20x9 -12 Offset,All Chrome Plasti-Diped
My Up Coming Mod's,McGhauphy's 7"-9" Economy Lift Kit,Federal Couragia M/T's 35x12.50R20Lt's,OEM Tow Mirror's,Bushwaker OE Fender Flairs,Gtr Lighting Led Conversion Kit's 2,200 Lumen(High,Low,Fog),Black Spyder Venom Bull Bar,Iron Cross HD Step's.
What brand rim is that. I have a hard time finding any decent rim unless they are XDs or Fuels. Truck looks great!
They are clean
Edited by 2014Sandylifted
Bmf
$$$$ lol
Bmf
Sir if
You would please add yourself to this fb page so you can talk some since into this numscull calling your truck a fact Z71
https://m.facebook.com/groups/171910943010512?view=permalink&id=347375682130703&ref=m_notif&notif_t=like
[fd144e40d4473cfafd12cbbc7c35d488.jpgquote name="CptMcSaug" post="1596538" timestamp="1426807732]Link doesn't work :(
There's the actual name of the group
Private group
Yea ill accept you in.
What psi are you guys running with stock P rated wranglers? I noticed my dealer filled my tires up to 40psi. The door says 32 so I lowered them to 32 and it rides a bit better.
Mine were the same, but my AT3s are set to 32psi rides great
Riding my wranglers at 35ish. 37 on a warmer day. Comfortable to me.
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 811 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
