I installed a 2" level and some 275/60/20s on mine and I can't tell a difference in ride quality at all. But I stayed with a 4 ply tire not a 10 ply
This is the exact set up I'm looking to get. Would you mind posting up some pics if you get a chance?
Also just wondering what leveling kit and tires you installed?
I did this as well. Running the 2" rough country with 275-60-20 Toyo Open Country AT2's. Great tire so far. I think I am going to upfrade to 285-55-20 or 295-55-20, the 275-60's are a little too skinny for my liking.
AZGMCZ71Leveled I'm pretty sure is the handle.
They are 20s with 33s worth the look. But aren't 18s
I have a Z71 Double Cab, with the "factory" 20" Aluminum Wheels, and I have the "Ready Lift" 2.25" levelling kit, and I didn't notice any difference in the ride quality with or without the level kit. I have not ridden in a similar 2014 with smaller tires, so I don't know what the ride quality would be in that case.
I would expect that the smaller tires, with the larger sidewall would provide a somewhat better (softer) ride in any case.
REV
See this is the problem lol. You can't have people that say there's no difference in ride quality at all, and then have people who say there's a definite difference. I don't like those odds.
I'm going to return my Zone 2" level, or sell it locally. I think I'll just stay stock until I can do it right.
I had a feeling a 60$ level kit was too good to be true.
In theory a block at the bottom of a strut shouldn't affect the ride, I am pretty sure I have way over tightened my sway bar linkage. I will loosen it tonight and update if it affects the ride quality.
REV
Sorry.....double post....don't know what happened, when I pressed the post button, it added it twice, and I don't know how to delete one, or if it's possible.
Edited by revitupfaster
I wouldn't be afraid of a 2" level at all. The wheel/tire size can play big difference. If you put a level and stick with stock tires and wheels your good. Sticking with P rated tires helps or if you go 10 ply, choose a 65/70/75 middle number. Mine rides rough because of 55 middle number and not enough sidewall height to dampen impact.
Yup this is the set up I'm probably going to go with. I like that the 275/60/20's are P rated.
I find going to 285 from 275 almost always means going from P to LT rated tires, and also means about a 30% increase in cost.
I installed my bottom spacer 1.5" level kit yesterday and I find the ride is very rough. Not sure why, I thought these spacers weren't supposed to affect ride quality, but it definetly hits the little bumps in the road a lot harder now. I think I may be going with the rancho qiicklifts sooner than I expected and setting them at a lower setting. Everyone else says they can't tell a difference in ride, either theyre not as picky as me or they're lying to themselves in my opinionm unless there's a chance I installed something wrong. All I did was loosen the sway bar and pry the shocks up to fit the spacer under.
There should be no reason for it to change your ride quality since you haven't changed anything other then ride height. You don't have a Denali do you??
All terrain, I am going to try loosening my sway bar linkage tonight.
Strange. I'll be putting my RC 2.5" kit on Tuesday so I'll see how that goes. Only ride change I'm expecting will be from the LT tires. We'll see!
I didn't follow the instructions and I tightened my sway bar linkage all the way as tight as I could. Apparently you are only supposed to tighten them until the bushing bulge. I will probably buy new sway bar links and bushings just to make sure they are good. I also tightened them with the vehicle lifted. I will update after I have loosened mine off.
Took a few more pics today not sure if they are necessarily "better", but here they are anyway.
Picking up a Hypertech Max Energy to fix my speedometer today.
This truck looks perfect to me! Could you tell me the exact tire size?
    • My post above is the direct reason for my outsized interest in keeping what I have for as long as possible. My memory isn't as short as some.
    • I don't think so. 😏 Cars? Our experience will diverge there as well. I was buying cars with 200K (1970's) when I started and quite a few were pretty solid cars. (My early stuff was 1964 to 1968)  Some stinkers but not the dismal picture painted above. Now that said, yes, a dealer wouldn't talk to you if your car had more than 60K on the clock and lot cars were 60K or less except the back row where 100-120K was the auction bought for dirt for us poor losers. Kids in my county were not allowed to wear long pants if they couldn't rebuild and repair every part of that beast.    I will agree that many parts are now better. Alternators and charging systems are an envy. But I replaced few water pumps or power steering pumps then. Rebuilt carburetors but replaced few. Mufflers are another place of OEM improvement. Stainless? We didn't have no stink'n stainless.    As long as humans are in charge of governance this $$$$ situation will not improve.    The purchasing power of a dollar in 1955 is significantly higher than in 2025, meaning that a dollar could buy more goods and services in 1955 compared to 2025 due to inflation over the years. For example, what you could buy for $1 in 1955 would require approximately $10.50 in 2025.  Calculator.net inflationtool.com   Comparison of Purchasing Power: 1955 vs 2025 The purchasing power of a dollar has changed significantly from 1955 to 2025 due to inflation. Below is a breakdown of how much more money is needed in 2025 to match the buying power of a dollar in 1955. Purchasing Power Overview Year Equivalent Value of $1 in 1955 1955 $1.00 2025 $10.50 Key Points Inflation Impact: The value of money decreases over time due to inflation, meaning that the same amount of money buys fewer goods and services in the future. Example of Inflation: What could be purchased for $1 in 1955 would require approximately $10.50 in 2025. This illustrates how inflation has eroded the purchasing power of the dollar over the decades. Understanding these changes in purchasing power is crucial for financial planning and assessing economic conditions over time.  Wikipedia Calculator.net
    • The thermometer has been in my wife's 2008 envoy, my sons 2016 chevy, my friends 2020 1500 silverado all showing cooler readings. It's not the guage.
    • Have a question concerning trim levels. Ive not bought a new vehicle since 2006, and I have decided on a 2500 gmc pro or silverado custom. For anyone that has one of these 2 trim levels have you regretted not stepping up to the LT or SLE. I look at things as the more electronics the more problems to arise. I love the look of the old school gauges on the dash as well. Looking forward to hearing your thoughts.
    • If that guage has a way to adjust [hex on bottom], put that thing in a glass full of ice, put water in, put your gage in, let it sit for 3 minutes or so, and set it to 33 degrees.
