I have the rough country 2" leveling kit ready to be installed, but I'm concerned how the truck will look once the leveling kit is installed and when I pull my 28' travel trailer. I dont want to be one of "those people" that looks like their TT is too heavy for their truck and makes the rear look saggy...
Do an "add a leaf" or airbags and you will prevent that all together
I had a 2.5" Rough Country with rear blocks installed this week. I had 275/65/20 BFG KO2s installed today. I wanted to try 285/75/20. I think they would probably fit.
Does anybody know what measurements the alignment should be after a level?
whats up new in here, just got my 2015 Tungsten Silverado double cab LT. Want to throw on some Fox 2.0 IFP leveling shocks. I believe those are good for 2.25 level. Wondering if +31 offset wheels will rub with 295/55/20 or 305/55/20. Anyone input much appreciated!!! Thanks
just got my Silverado the other week. this past Saturday night my neighbor and I installed the rough country 2.5 kit along with the new wheels. started around 8 finished at midnight. We took our time and enjoyed some silver bullets during the process. Love the result, exactly what I was looking for. seemed like a quality product and install was fairly easy. I have been wrenching on muscle cars since I was 15 ( currently 31) and this was my first "lift/level kit" had a few beater trucks in the past, always wanted a nice Silverado but could never ever live without a GM V8 car. finally got to a point in life where I could have both!
Did you stick with the stock shocks? How about the rear block did you add that?Also did the leveling kit come with rear shock extender mount for the shock itself?
New to this site I have a 2014 Sierra Denali I want to put a 2.5 front 1 rear with 285/60/20 on a stock off set does any one have this setup or know will it work without rubbing
285/60/20 should be fine on stock set up with a 2.5 kit
Eventually when my stockers are shot I'm going to go 295/60/20
Yes I kept the stock Rancho shocks. I removed the 1 inch rear block from the factory and put in the 2inch block RC supplied.
In the 295/60/20 I like the toyo open country AT 2, in my second choice 285/60/20 I like the Goodyear Duratrac
I was looking at those same tires there doesn't seem to be a whole lot for the 285/60/20 but I haven't looked to hard at tire brand yet still trying to figure out what size I want to run
I am currently in the process of deciding what rims and tires to get for my truck as well. I installed a 2" Zone leveling kit, and I am going to get 20x9 Fuel Hostage, and I finally decided to go with the Deegan 38. It has an aggressive look and is under $300 per tire, plus reviews are great for on road, off road, and in the rain and mud. i also like the look of the toyo MTs but the price puts them out of the picture. Good Luck
Do u have pics of truck with the fuel hostage wheels I really like them wheels
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 827 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
