Finally installed a Motofab 2" leveling kit on my shortbed two-door. Truck still has 1-1/4" of forward bias.
You have any more pictures? Can't decide if I want to lower or level my '16 regular cab.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Rough Country 2” leveling kit, 2017 Z71. Not the best picture.
It’s now about 3/4-1” high out back, a bit less than 2 full inches of lift. Got it done at a local shop.
It’s crazy how much of a difference it makes in the feel looking out over the hood. Definitely like it. No ride or drive difference, all good.
295/70/18 on 18x9 method wheels on a 2.5” leveling kit
My 2018 Z71 4x4, this is my first post!
Just put the 2 inch level on yesterday, but I've already done the superchip programmer, Cquartz on the entire truck inside and out, tint on every window, 3 inch maganflow exhaust and 33 inch Nitto Trail grapplers. 2nd pic is before leveling kit just a better pic. Next mod on the way is a Gator bed cover! 05ab8cba26c7d4c67dad753c28ebff92.jpg5714d614ea64c53ea669ba3942b8fd30.jpg
How much rubbing do you have with the 295 width? Are your wheels a 0 offset?
On 19/10/2017 at 6:40 PM, SierraElevation said:
2015 Sierra Elevation - 2.25" Front and 2" Rear Blocks. OEM rims with 285/55R20 AMP tires.
I like the slight rake.  2" block in the rear - is that stacked onto the factory 1.25" block?
33x12.50?  Any rubbing?
Hey guys, I hate to be the will it fit guy but found a set of slightly used wheels and tires that are damn close to what I had planned on purchasing new and I'm wondering if they would work with my setup....
Currently running a BDS 2" level on a 2015 Silverado 1500, crew cab, standard bed 4x4.
Found a set of Fuel Mavericks wrapped in 295/60/20 Nitto Terra Grappler G2's. Wheels are 20x9 with a +14 offset....
What are the odds I could run this setup without rubbing? Don't mind trimming my carpet fender liners or removing the lower valence but I DO NOT want to have to trim or modify metal.
2014 SLT 4X4 with 2in RC level and P275/60r20 on stock rim.  Hankook Dynapro ATM.  Love the look and tires.
IMG_20171023_183409_587.thumb.jpg.dc59e7e4279c887fd36fd674be3dd410.jpgHey this is my 2014 Sierra with a 2.5" leveling kit with the rear blocks. Was super easy did it in the garage. Just had my new 33x12.5R20s Haida Mud Champs installed and had the balancing beads thrown in. No running or trimming I also put my gatorback mud flaps back on as well with no rubbing. 20171023_173039.thumb.jpg.ffe2e41a2f4ebe6712c1cba1876e8aae.jpg
Edited by Braedencrepeele
On 9/24/2017 at 10:09 PM, Criscone said:
Took some new photos today. No issues at all with this setup, except wanting to go higher without cutting my truck up..
RC 2” front level only
33x12.5x20 tires (305/55/20) says both sizes on tire
20x9 +0 wheels
c116dc74a62cd39b6bd01ae1b85ae0e7.jpg203159b7c290cb5b06d5d499e149ba6c.jpgdec9eb9db3c2872c2897f47b88ebe946.jpg
Out of all the pics i've seen, I think this look is my favorite. One of the other poster said it give it a beefy look. I'm sorry for the ignorance but if I wanted a similar look but not that big of tires, what would be the next best option. I'd like 20 inch rims on it but I just dont know too much about tire sizes and offset. I dont want any rubbing nor trimming.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,238 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
