BFG KO2 275/65/20 - no rubbing issue with 2" RC level and zip tied liners.
Exactly the setup I have been considering for my 17 Sierra. How much difference is the road noise/ride? How much has your mpg suffered?
I had the level and 276/70R18 K02's on my 2012 Silverado and they looked and performed great. Nice looking rig!
I have been searching through this post for a while, and cant find exactly what i am looking for. I have a 2015 All-Terrain that has a 2" level kit ( i don't know the brand, bc was put on before i bought it) on front and an 1.5" zone body lift. I am going to be needing tired in next couple of months. Currently have 275/65/20. Is this the largest can put on with no rub?
All depends on wheels. I run a 305/55/20 (33x12.5) on a 20x9 +0 offset wheel. One zip tie = no rub
Who is actually running a 2.5” with stamped arms? Curious to see how bad the angles truly are.
I don't have the lift yet, but this shows what a 2" would do. Later today I'll post some pics of a 2.5. You can see the CV isn't too bad, but look at the upper ball joint in both pictures. ( click on the picture)
http://www.gm-trucks.com/forums/topic/200377-some-info-on-cv-angles-with-a-2-level-lift/
Thanks! So far road noise has been minimal and the ride has been fairly smooth. It drives a bit more like a truck now but stock it drives like a Cadillac so no complaints. I had to take it back on the check the balance as I was getting vibration over 70. Guy said these tires need to be rebalanced sometimes... all good now.
Nice - Thanks for the report!
2015 Silverado LTZ 2.5 front, 2 inch back inch leveling kit with 285/65 r20 minimal rub on passenger side at full lock.
20161009 002151
20160921 181201
20160921 181218
Nice job - looks good! Entertaining how much bigger your truck is next to the white one (assuming that is stock height).
Out of curiosity what does the height of the tire measure out to while on the truck? Also interested to see the fender heights if possible.
Just did the 2" level. Considering a suspension lift in a few months or so but was thinking about throwing some toyo open country tires on my stock 20's for now. What's everyone running on stocks? I don't want to trim anything, looking for something that won't rub much. Truck is a 2017 Z71 1500
I have the 2" level and put 275/65/20 on with no rub issues whatsoever. I had to zip tie the rear of the front liners but that's no big deal. You will run into problems when you start trying to go wider with the Factory 20s.
Searched for two days now...... Anyway i have a 2016 LTZ midnight editon. i am looking at leveling, my question is for Nitto trail grapplers, can i run a 285/65r18 or the 275/70r18 on the stock 18's without rubbing? there seems to be some that are making things work without cutting and others that are saying it cant be done. I'm at a loss on what to do.... TIA
What is everyone's thought on the MotoFab lifts? Looking at purchasing the 1.5" level kit for my 2014 1500 Denali. Thoughts are welcomed.
Does anyone have a pic of a 14 or 15 Silverado/Sierra Crewcab 4x4 on stock 17's with the 2.25 front level only ?
    ncleg
    ncleg
  • Who's Online   2 Members, 0 Anonymous, 1,229 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
