Mcgaughys Suspension 3/5 - 4/6 drop
Hey guys,
New to the forum and am looking to drop my 2014 SLT 4x4, found this kit and emailed them. They said it would work, does anyone have any experience with this company?
Drew
IMHO trucks go up and cars go down... Sent from my Galaxy Nexus using Tapatalk 2
Lol, I appreciate the opinion. Mines different I like to park in parkades, I like my dogs to be able to jump in the truck not be lifted and I like to not have my trucks height associated with my manhood lol
I know a few guys with the McG kits on GMT-800 and GMT-900 trucks. They haven't had an issue
Yah I love that look! R/c doesn't have a kit for the 4x4 yet. Tried asking them if they were getting it but they haven't replied and it's been a week.
I'd like to see a 3/5 drop but I think it's going to be too much...
It will look good lowered. Lol'd at the comments of some in this thread.
I agree, I don't understand why some people don't like lowered trucks. As long as there not slammed on 30 inch rims and they're still driveable and can tow why not? To each there own I suppose. I like lowered, lifted, and stock trucks. They're all pretty bad if you ask me. :cool:
*edit double post.
I would lower mine if I didn't have to tow a large trailer. I like lowered 2wd's with tasteful wheels
I would drop a 2wd or AWD, as long as Im not gonna use it for towing. That would be my "go fast" truck, like a 2wd SS with a blower or turbo'd 6.0
    Fishboat
    Fishboat
  • Who's Online   7 Members, 0 Anonymous, 491 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
