2014 Exhaust
I was thinking of adding a cat back system. I have not found much on HP and TQ results. Anyone point me in the right direction? What did you use and why?
Exhausts don't really add much in the way of power, mostly just ear candy. Duals tend to cost some power down low, but add more at upper RPM levels. Personally, I have a dB (Corsa) exhaust on my 2011 and wouldn't consider anything else for a GM V8.
This is a video I made after installing it in June of 2011:
which exhaust set is that set up is that and who did your tune? If my 09 shifted like that I would never tune...(if I heard that drive out right)
dB Exhaust. Corsa's less expensive brand using lower grade stainless. 3" pipe all the way, single exit. Tune at that time was done by General Motors (stock :lol: ). And it sounds weird because I let off about where it shifted I think on each run because I didn't think the camera would pick up audio good as I got further away. The only clean shifts are during the interior audio at the end. Truck is now Blackbear tuned.
Exhausts usually don't do squat for power, but these are some pretty restrictive setup s hence the lack of any sound whatsoever, but still you may only gain like 5hp. Long tube headers and hi-flo cats are where it's at, or no cats at all.
As far as I know there are no tuners out there for these trucks right now, what you want for some real nice power gains and way way wayyyy better shifting is a custom dyno tune followed up by a street tune.
I have a flowmaster catback, that and magnaflow are the only options out there. Normally I'd to w/ magnaflow but it was almost twice the price and they're both 409 stainless whereas flowmaster is usually alumnized mild steel, since they're both made from the same grade stainless I figured go for the cheaper system, also I like that you can run the flowmaster out the side or straight back in the same system.
If you're going to add a catback keep in mind it may very well sound like dog crap no matter how much you spend because of the AFM system, when it goes into 4 cyl mode it'll drone like a bastard, which is partially why I went w. the flowmaster, it's pretty tame. Adding j pipes to the muffler can help w/ drone.
If you're worried about exhaust flow, you're barking up the wrong tree with a "flowmaster". They are more restrictive than the stock muffler.
OP, many people on here have replaced just the muffler and kept the stock piping. It will sound the same as a catback, but the cost to switch out just the muffler is much lower.
Whatever you do, it's unlikely you'll gain much but sound. Still worth it IMO.
Seconding this, Corsa is pretty much all I use these days. The construction is fantastic and the lack of drone is a big plus, especially with headers. The Corsa system is also about as unrestrictive as you can get for an exhaust. The muffler is a straight through pipe with channels cut around the circumference for the various passages for the destructive interference at specific frequencies.
If you're worried about exhaust flow, you're barking up the wrong tree with a "flowmaster". They are more restrictive than the stock muffler. OP, many people on here have replaced just the muffler and kept the stock piping. It will sound the same as a catback, but the cost to switch out just the muffler is much lower. Whatever you do, it's unlikely you'll gain much but sound. Still worth it IMO.
I don't think any of 'em help much. Like I said I got a flowmaster because the price was right, it was stainless, it had side exit pipes, and there's nothing else out there besides magnaflow which was more $$$ and I've already had some magnaflow mufflers on my G8 they were OK kinda tame, but I've always done custom exhausts- G8 system went sterling coated JBA long tubes, custom 3" connection pipes into 2.5" magnaflow X pipe into 2.5" straight pipe, into magnaflow axlebacks. If I don't like the sound of the flowmaster I'll swap out the muffler - that's what's nice about a flowmaster system - I could go w/ borla or corsa or whatever else. I just like the side exit pipes and wanted to hear "something".
I wouldn't want to just cut up the stock catback just yet, I think it would be wise to keep it intact in case I wanna go back to "quiet" mode and cat get rid of the drone
  • 3 months later...
I too will be getting Corsa for my 2014. I have had Corsa on every vehicle since I was 18 (27 now) and it's the only option in my opinion lol. I emailed them a few weeks ago and they told me the kits should be out first month of 2014.
  • 6 months later...
I have Corsa Sport on my truck sounds great. V4 mode has a little "helicopter" sound, but soon AFM will be tuned out.
Is the V4 sound obtrusive with the windows up?
I have the same system on order and should have it in the next week or so and that is my only concern is how it sounds in V4. Thanks.
    FiLo
    FiLo
  • Who's Online   4 Members, 0 Anonymous, 542 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
