Few of mine in my 2010
Ryan
My camaro has yet to catch anything
Ryan
RyanMy camaro has yet to catch anything
Ryan
How many miles do those represent?
35,278 Drained Catch Can 1 tablespoon 38,646 Drained Catch Can 3 tablesspoons watery 41,071 Drained Catch Can 5 oz
The really full container was during winter. Lost of moisture I believe in the catch can. It is now black to a darker color. Drained yesterday at 42866 and barely got anything.
Is there any definitive proof that these catch cans are beneficial? I can see that they capture some oil but are the intakes/valves any cleaner than those without the cans?
^^^^ That's nasty and precisely why I sleep better at night with mine installed.
Sure, you can post up a video someone else has posted to prove your point. But I'm asking is this: HAS ANYONE BORESCOPED AN ECOTEC WITH A CATCH CAN TO SEE IF IT ACTUALLY MADE IMPROVEMENTS?
I would prefer if this was done by a forum member or someone who doesn't stand to gain financially from posting you tube videos of these supposed benefits...
I had a few performers in my time never did the catch can, cheep insurance I guess. I usually don't go to far pass 150k on the miles never had a problem, I guess the next owner will thank you.
Drained my catch can for the first time after 1K miles and was actually surprised at how much it caught in that short time. I didn't have anything handy to measure the quantity so I just put it in a shot glass I had laying around. So far very happy I decided to add the can.
Newm: Thanks for the update. From what I saw in your install pics, you didn't buy the clean side separator contraption that goes on the oil fill hole on the valve cover? I'm leaning towards just ordering the catch can.
Correct...I did not install the clean side separator. I was told that the catch can will stop/catch 90% or so I just went that route. That and there are two clean side separators on the truck and they only have the one for the drivers side figured out so far. It's my understanding that they are working on a solution to the passenger side but until then I am happy. I will also add that when Installing and looking at both clean side inlets to the air box they were 100% dry with no evidence of oil/crud.
Edited by Newm
Thanks! I'm gonna be ordering the just the catch can from RX.
Wait so when you installed the oil catch can, you noticed the clean side inlets were 100% dry with no evidence of oil/crud? Meaning the clean side separator is not that critical to install then?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
