Here she is. Mods so far:
Amp power steps
5% tint w/70% on windshield
Husky x-act floor liners
Extang Trifecta folding tonneau
Rhino extreme bed liner
My lift, wheels, tires and exhaust should be in this week. Been waiting forever it seems. I will do a build thread when everything gets here.
Oh, and I forgot I have Cree 5k LED headlights. Stock bulbs suck.
Looked at those...vled does not recommend use in projectors. Know why?
LED bulbs are designed specifically for use in reflector housings because they focus the light differently than the projectors. Therefore the bulbs are more effective in reflectors than a projector, and for the business and advertising side of it, they don't want someone to purchase the bulbs and then go around telling everyone that they are terrible just because they were used in a projector housing.
Given their recommendations...do they work at least as well as halogen bulbs in this application?
Yes. Have had them in for about 3 months and they work great.
Stock 2014 AT. I like to park away from everyone else at work.
So do I.
But the problem is that's an invitation for some jackass to do this....
Or this.......
fairladyz10pg-albums-close-call-parking-
Edited by Luster
Which of course is an invitation for you to do this.....
30+SOCK+Tina+Fey+seen+smashing+car+winds
  • Like 8
    • ^^ Yep, that's all it was. The fuel line had rubbed through on one of the spider legs and was severely leaking. Even the lines/nut and bolt kit are harder to find and I think I paid $84 (Standard HK-11) for the kit. Ripoff. But when you're the only brand still making it...   There are a few things left before the truck is Atlas® Certified (and I've thoroughly spent too much on it considering what it's worth). My RockAuto shopping cart total is about $250 and growing:   -Radiator (there's a pinhole leak, driver's upper corner where a cooling line bolts in, the threaded insert weld cracked) -Water pump (mine squeaks, I assume it's shot) -Lower radiator hose (it's original, if replacing cooling parts, this shall be touched too) -Starter (It's not always engaging the flywheel, get the whirrrrrr sometimes when I turn the key but no crank) -Door hinge replacement pins (already purchased, need to install)   Suspect/borderline parts NOT included in shopping cart (only if I want to opt for bonus points): -Motor mounts. Someone twerked the radiator fan shroud, so I can't tell if the motor mounts are bad/squished or if it's truly just a deformed fan shroud. I reassembled the shroud correctly but the plastic is still re-forming/relaxing where it was all mangled and bent, and the fan still chafes it occasionally, but it's 99% better. -Left rear door speaker is blown -Rear wiper motor is shot (horrible grinding noise) -One of the wheels is missing the bowtie center cap. This drives me insane to look at, I'll just need to find a replacement.   I've already replaced: -Driver's door mirror -Idler pulley -Tensioner pulley -EGR -MAP sensor -Hood prop retainer -Intake plenum fuel lines -Intake gaskets -Thermostat (and flushed cooling system) -Radiator cap -Radiator overflow reservoir cap   And it needs tires, and could use a set of front brake pads, and the brake system flushed. And it could use a transmission service, and if I'm doing that, why not differentials, and transfer case, and oh hell, why not flush the power steering.   Is there anything I won't touch? Or...do I just get it to a point where I can send it down the road?
    • Was checking out a 39 Buick at a charity auction and found the statement on the cover of the owners manual interesting. What it can do for you, and what YOU can do for IT? Framing your ownership as a two way relationship! Seems this type of thinking is all but gone with the non-enthusiasts, and something like that would never be printed on the cover of a manual. It would likely offend people. Hey, I just spent two years salary on an SUV and it has the nerve to request anything back from me???? 😂
    • thanks, I'll look for that now.
    • Make sure your phone software is up to date.  Some people have had issues lately with bluetooth on GM radios and their phone had a security update or something that fixed it.
    • Assembly Turorial   https://www.msn.com/en-us/autos/news/here-s-how-cruise-control-actually-impacts-fuel-consumption/ar-AA1MJ3a4   Take the time to read the link and the document linked note how the writer parses the wording to reach unspoken information that is just as important as the information presented on face.    Some procedure works for marketing presentations.    Maybe you might wish to reconsider; 'Critical Thinking'.
