I'm looking to get a 4 inch suspension lift for my 2014 silverado. Can I see some pics so I can get an idea what it will look like.
Also I'll be getting 20x10 fuel Mavericks with 33 inch trail grapplers
Almost exactly what you are looking for, 2.5" level 1.5" body 20x10 and 33s
I just put on the "winter wheels". 22" chromies go back on in April.
These are my favorite rims on these trucks anyways. I bought a z71 with 18's my second go round'. My first had these and had terrible vibration issues. Edited by 20Bowtie14
You might save money but 4x4 are more useful and here in AZ the market is flooded with 2wd. 4x4 ups the value and I have never had an issue with 4x4. Now awd, that's another story, my wife's denali was a nightmare.
I really like your truck man. I really wish I would of spent the extra cash for a 4x4 now. Lift, wheels, and tires look great and compliment the body lines real well.
Thanks man.
Decided to plasti-dip my wheels. I'm happy with them. Cheap way to get a different look. Sorry about the dirty truck.
Edited by Yamiryder
  • Like 4
4wd cost is more than recouped on resale here as well.
attachicon.gifTruck 1214-1.jpgattachicon.gifTruck 1214-3.jpgattachicon.gifTruck 1214-4.jpg
Where'd you get your taillights anzo?
The Taillights are Eagle Eyes. I have had a set from the same company on my corvette for several years without any problems at all.
The lights look good and easy installation.
http://www.ebay.com/sch/sis.html?_kw=PAIR+%22L.E.D.%22+LED+TAIL+LIGHTS+SMOKE+PLUG+N+PLAY+FOR+2014-2015+GMC+SIERRA+1500&_id=301219134579
From the other night when I installed my VLEDs! There was a heavy mist/fog that made for some pretty cool picture opportunities!
I was thinking bout doing that set up as well with the light bars. How does it look with both light bars? Is it worth it ? Did u make a bracket for behind the grill ? And how did you rig it up in ur truck ?
4F4F8A75-6BF9-4507-9F8A-BF500CD47F12_zps
B054DC8E-DD7A-468E-B52C-887677FC4C07_zps
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
