Hey... Could you fill me in on your Chrome trim tail lights and the Chrome Tailgate Latch... Make and Model, Self Install, Prices, Where you got them... Been looking for a pic of a truck with them and finally found yours...
Also... Looks like we have the same OEM Side steps... Are yours open at the ends like mine.. In other words, no caps... If not, any concerns? I think they may rot, peel, degrade, etc faster...
Thanks for your time,
Dan
Those are all over ebay. Do a search for 2015 Silverado and it's one of the first matches.
Rawyzf... Thanks bud... I didn't realize they are just a trim piece the sticks on the tail lights...
1MOGAM... Is your tail gate Latch the stick on Chrome trim as well... They look great in the picture from 6-8 ft away... How do you like them? Any issues with the rear assist camera on the latch using the chrome stick ons?
Thanks Fellas,
Dan
Finished product
Day time running light.
That looks great man! Are you going to do a write up on how to get the SLT lights working on the SLE's? Previously the thought was that getting the DRL's was not possible on the SLE's.
Thank you! Actually these were plug and play. There is a guy on gen5diy that sells the oem lights with the harness already set up for it to be plug and play. 1400 is the price but i got him down to 1k because it was his last set. I can provide you the link if interested ?
That's honestly not a bad deal. I know the Ford HID Projector headlights go for ~$1200 on ebay with a similar plug and play harness. The SLT headlights are great looking and drastically improve the daytime appearance of the truck. I found the website too, had never heard of it.
I think if I was to spend $1k on headlights, it would be for an FXR projector retrofit. That's just me though.
Added gmc caliper covers
Nice, what size tires are you running, and how much were the covers?
$200 off carid.com. They have different colors
Thanks, and I do agree it makes me love the truck more. Remember that you can always sell the spare lights to recoup some of the costs. If you go ahead and do the projector retrofit post up pictures. Either way i bet it would look sharp
Pretty old picture, but shows the front end of what mine used to look like and what it looks like now.
Let the idiots start the bash but guess what! This thing towed 5000+ feet of elevation and did great! Trailer loaded only was 8500 pounds loaded with only 1100 hitch weight and I still got 8.0 mpg. Towing a 5th wheel is so much better then an bumper pull!!!!!f41af8136fde4e5c46c507534462d13b.jpg
  • Like 7
Bought a Silverado Rally 2 edtion for my wife, love the changes to the truck from my 07 Sierra SLT
Looks great! Wonder why they didn't go white around the headlights as well? I love those wheels.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
