To you guys with the RC 2.5 kit, did you notice any difference in ride quality? I know it makes your shocks be "stretched" all the time, but how does it impact the ride?
Only have a few miles on mine but very happy with it so far, hit all the normal bumps on the way to work and didn't seem any worse and drove back in the field to see how slow big bumps and ruts would feel and it feels great
Mine seemed a little stiffer but I would assume it is due to stretching out the suspension more than stock. It is nothing that bothers me though.
2813dea3eda01e3e7ab0e62222b27c3b.jpgTRex
I absolutely LOVE this grill.. I wanted it before I even got my truck, was about to order it today until I discovered you have to hack up your factory grill :( (at least for the Denali, according to the video I watched earlier) But in the second picture, it looks like the chrome frame is just a separate piece? Did you have to hack up the factory grill? I always hesitate to do anything to my cars that I can't revert back to stock.
Yeah bro, you gotta cut the stock center chrome grille out to install the after market grille, it was not that bad, it was pretty easy
Update on my baby 2.5 rough country 33 12.50 20 mud tires with -12 offset post-140612-143545886346_thumb.jpg
Sent from my XT1080 using Tapatalk
anyone have pics of a silver Silverado with a black or tinted chrome (black chrome) grille and bumper? not a big fan of chrome and just exploring other options..
Anybody with rough country 3.5" lift.
Sent from my iPhone
using Tapatalk
post-141988-0-59751400-1435496171_thumb.jpgpost-141988-0-09899800-1435496193_thumb.jpgpost-141988-0-05145800-1435496209_thumb.jpg
This one is for sale locally, Zone 4 1/2 inch lift with 33.5 inch tires. love the stance
Day 1
Debagded and carbon bowtie
Camo seat covers
Grill
Where u get the camp seat covers? And how much did they cost u
Well welcome and that is a good looking ride you have there, and I enjoy your acronym.
FNG here.
I just picked it up tonight. 2015 GMC Sierra 1500 SLT Z71 Double Cab 6.2 8-speed.
Congratulations. That is a good looking truck.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
