New on this forum. Has been very helpful in finding the set up I wanted to run after endless hours on here lol. Bought my 16 Silverado 1500 2 months ago. Finally installed my lift last week. I'm running the 5" rc lift (bracket kit- keeps stock track width). Kit says to remove stock block from rear. . . I kept mine in I like the raked look. (Can't tell by these pictures will post better ones later) running moto metals 20x10s on nitto terra grappler g2s. Very minor trimming on inner lower valence. Other than that rides great! Imo I think it looks great!
New to the forum, got this 2016 SLE All Terrain back in March. Not much in the way of mods going to happen as i'm leasing it...but maybe a few items besides the tonneau cover as i'm currently looking for side steps. I do love the truck though, so most likely going to buy it out after the lease term. Just love the looks of the GMC over any other truck right now.
I've got a set of 4" black steps off my '17', will give you a great deal!
Sent from my XT1254 using Tapatalk
Good looking truck!!
So you stacked the RC block on top of the stock block? Bad idea. Go spend the money on a taller rear block if you like rake before you hurt yourself or someone else driving behind you.
I know this isn't everyones cup of tea on here but heres some new Denalis to replace my old ones.
Drove out of the dealer at 10pm Monday after trading in my 2014 black Denali with this White Frost Tri-Coat 2017.
Loaded up my wheels and brakes that were still in the package that were due to go on the 14 and right to my mechanic it went.
By the time it was 10 hours old it had the factory rotors and brakes replaced with cross drilled and slotted rotors and beefy pads and these gloss black Dub Baller 26's on.
I absolutely love it!
Tint goes on Monday and gonna shackel the rear to level the ride and eliminate the rake.
With the addition of the magnetic suspension that my 14 didn't have I would have to say that running 26's gives me the same if not a slightly better ride then the 14 running stock 20's.
And the transmission is a million times better.
Also traded in the wifes 2015 black Yukon Denali and went with a 2016 XL in White Tri-Coat Frost. Hers came with 20's so I had the 22's that came with mine put on hers and her tint goes on Tuesday.
Both went white cause black was a full-time job to keep clean and I have to say the Tri-Coat is beautiful.
Looks good just needs bigger baller brake package. Stop tech 6 pot BBK would look amazing. I like it
Ah man, this is my exact truck (minus the level and bigger tires). Any issues with those 305's on the stock wheels? How's the ride and MPG's....
Had some rubbing on the sway bar. Had to use 1.5" wheel spacers, front and back, to get the offset look I wanted with the factory wheels and that made the sway bar rubbing non existent. Has very minor rubbing on the inner fender at full lock but not every time. Rides like crap. I'm not a fan of Ranchos. Bilstiens will go on this week and I'll report back. Havent really drove hwy much but looks like around 16-17 mpg. May have to go with a little "calmer" tire to get some of the ride back as well, the farm truck needs rubber so might do some swappin.
What tire is everyone running in the "all terrain" class that rides good on highway?
Edited by White Wizard
Thanks man! I didn't think I would get any positive feedback as I know most on here go for the lifts and offload look (which is also great looking!). I would love to do the big brake package but unfortunately I live in New Hampshire so these are just part-time wheels, for lack of a better term-lol. I gotta put 20's on with my studded snows for some of the year so I thought this was a happy median as I found the big brake kits didn't work with the stock setup.
I believe that the bbk I spoke of should fit under 20's. It's the same as the one I'm looking at for my truck (20x9+15).
