Man that looks great
Thanks, and same to you! I wanted a Z71... Couldn't sell it to the wife tho :D
I was lucky mine was at work [emoji23][emoji23]
a little vinyl and a little time and you can customize that red Z! ;)
What's the specs on your truck? Thanks
I was thinking about it but then I also removed those emblem and reinstalled I think I’m gonna keep them red thank you
2017 LTZ Z71 CC
20x9 fuel Savage
Falken wild peak 35/12.5 M/T
BDS 6” Lift with fox rear 2.0
Amp research power steps
GM Cool air
D badged and then Reinstalled the Z71 emblems back on the doors
This week:
Illuminated bow tie
Driver assist handle
2017 LTZ Z71 CC
20x9 fuel Savage
GM Cool air
This week:
Illuminated bow tie
What's the offset on your 20x9's and how many lugs worth of tire are outboard of your fender? Do you have a pic straight down the side of your truck from the front corner?
Looking to run a 6" lift and 35's but trying to keep as much tire under the truck as possible to avoid needing fender flares. Local shop said the best I could do is run a 9" wide wheel with a high positive offset. So I'm curious/excited to know your results since your setup seems similar to what I would run
I forgot what the offset was I’ll get a hold of my buddy at SoCal super trucks and find out what it was and when I get to my other shop I’ll take some pictures for you
Thank you very much!!!
Just got my 2017 GMC Sierra 1500 CC Base trim. Looking at getting new wheels and tires. What is the biggest wheel/tire i can do with or without a 2 inch level. Looking at getting Toyo Open Country C-T. Thank you
I think! 275/55r20, maybe a little wider
