33 minutes ago, ObscureGlock said:
Love the truck. Where did you get your mirrors? Been looking to get some for mine.
Thanks!
The mirrors are GM OEM. I ordered them with the truck and installed them myself. The part number for the mirrors is 23371780. They are NOT power folding.
There are several great threads about it here already but if you want full functionality for the lights and don’t already have mirror lights you will need new door harnesses, as well. There are some folks that make harnesses but if you want the OEM harnesses, they are parts 23342729 (driver side) and 23342715 (passenger side).  Those harnesses and the mirrors will effectively change you from a DL8 to DL3 (minus power folding) RPO code.
I also ordered smoked turn signals and relays from Boost Auto Parts to get turn signal functionality out of the amber marker lights.  You can see the difference in lenses in the photos I posted.
Edited by Armo325
It might have stock Z71 suspension, but damn if I don't wear the thing out. BFG AT KO2 tires on stock everything. Flexin in the Gila NF in New Mexico.
Bonus pic of the campsite!
2017 GMC Sierra 1500 SLE Crew Cab Z71, with Ranch Hand Grille Guard, Auxbeam Light 32" and 50" Curved 5D Light Bar, MicTuning Tailgate Light Bar, LED Tail Lights, Fuel Nuts 20x9 Rims, 305-55-R20 BFG All Terrain KO2, LED Reverse Lights, Low Profile Bug Deflector, Window Rain Guards, 2.5" Levelling Kit so far is all installed. Waiting for 3D Third Brake Light to match the tail lights, Colour Matched Tow Mirrors, k&N Cold Air Intake 63 Series, Magnaflow Pro Offroad Exhaust, Go Rhino LED Bed Rails, Footwell LED's,  and Bushwacker Fender Flares, Probably also going to switch out the levelling kit with a 4" BDS Lift with Fox Shocks and Fox Front Coilovers.
looks good
Just picked up some 20x10 Hostile Havocs w/33x12.50s.   Wasn't really looking for black rims when I came across these but they look pretty nice.
Looks Good
6 hours ago, 6TEEN5.3 said:
Nice Clean look , Lift , Tires, any  Rubbing ?
Edited by Artie61
left out
Thanks! It’s a 3 inch spacer up front, nothing in the rear. Tires are 33x12.50r17 Ridge Grappler which rub on the upper control arms at full lock
On 11/2/2017 at 9:12 AM, harrison725 said:
Before and after picture of my 2014 Silverado z71
Nice truck! What foglights are those? Retrofit?
    • It’s probably water in the doors. Mine had tape over the drain holes! Poked them open and that took care of it. Now I’m waiting for the rust to come through!🤬
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
