On 11/4/2017 at 12:33 PM, slj2008 said:
HOW hard were the fog lights ??? are those rigid lights / bracket ???
It's the rigid bracket with cheap amazon pods which have actually really impressed me. I had to cut the plastic trim around the foglight to make them fit. I wouldn't say it was hard, just time consuming.
11 hours ago, m1ssm0rgan said:
Nice truck! What foglights are those? Retrofit?
Thank you! It's a bracket made by rigid industries with led pods I bought off amazon.
On 11/11/2017 at 1:57 AM, blue2003ls said:
Just picked up some 20x10 Hostile Havocs w/33x12.50s.   Wasn't really looking for black rims when I came across these but they look pretty nice.
Level kit? Any rubbing?
Bilstein 5100s up front set to 1.85” and a 1” lift block in the back. It rubs just a bit on the plastic on the back of the fender well but not to bad.
Edited by blue2003ls
On ‎11‎/‎13‎/‎2017 at 6:23 PM, grizz_wi said:
Last week snowy Wisconsin
Wish I had SNOW ???? looking good
On 11/14/2017 at 6:14 PM, 65VetteC6 said:
Any more photos, this thing looks good. What wheels are those?
Method NV 17's. I will post up more soon
2017 Denali Ultimate with a few small mods.
What have you done to yours? I have a Black ultimate.
Yes, they are the OEM wheels with 295/55R20 Toyo Open Country M/T’s. I also have 1-1/4” Bora spacers installed.
I'm guessing with the 1.25" spacers on you had to trim the studs down a bit? I have 1.5" Bora spacers in the garage but I can't bring myself to trim the studs on this truck. I did on my 2011.
Sent from my SM-N950U using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
