3 hours ago, wantavant said:
Do you have a level kit on this? If so, which one? Looks amazing!
It's stock suspension set up. Thanks!
Beautiful Truck...where do you buy those Volks?
Would it be a sin to put Japanese wheels on an American truck made in Mexico?
No more of a sin than to put Chinese communist wheels on an American truck assembled in the USA.
Got rid of the OEM badges on the tailgate and added a "retro" sticker instead.
I kinda like it.. Thought it was a GMT800 for a second lol. Reminds me of the 2000 1500 work truck I had. I'd like to see more pics of it with different lighting.
Looks Good
Stock suspension?  What size are the tires?
EDIT... Never mind, found your the size in another post.  Nice setup!
Edited by steve76t
4.5" BDS lift
295/55-20 Nitto Grappler tires
XM wheels. Centers of wheels painted Iridium Metallic to match the truck.
4.5" BDS lift
295/20x33 Nitto Grappler tires
That is bad-ass!! Looks awesome!
GOOD Looking truck - maybe some tint ???
Hey there from a new guy. This forum seems  like the place to be for finding out all types of info for our truck. Here’s a pic of my truck. Hopefully the pics works ok.
Edited by UltimateDenali
Picture is coming out sideways.
11 hours ago, Sideswipe505 said:
Brand new member. Just picked up a new rig today. Any suggestions for initial appearance mods? I’d like to paint match the grille. 0c43a08356dda29bf4f079782cf54081.jpg
Welcome -  tint , Bowtie ( RED or BLACK ) Black Letters / rim's .  Just check this sit it has a lot of ideals .
4.5" BDS lift
295/55r20?
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
