On 5/21/2018 at 11:59 AM, Skidsareforkids said:
As she sits with her Corsa exhaust and Suspension Maxx 1.5” spacers...
Which Corsa system did you go with?  How do you like the sound and is there any drone or any weird tone when in V4 mode?
I have the “sport series” model for the 6.2 and I absolutely love it! It did drone in V4 despite what the marketing says. I hated that, so I deactivated V4 mode with my Hypertech tuner. I noticed no decline in my fuel economy and am much happier overall. My favorite thing is driving in town in manual mode and letting it rev a bit higher. Letting off the gas in 2nd makes it pop and burble [emoji869]
On 5/14/2018 at 9:43 AM, jgomez713 said:
Took the family on a picnic in the woods.
Hi JGomez,  nice truck!   How do you like it?  Any favorite features?
I really love everything about it I get compliments on it all the time. Best for me the view in my driveway lol.
But hands down it is the 6.2!! CarPlay, and the automatic power mirrors and side steps are also great.
It’s just a beautiful truck inside and out. And honestly, it’s hard to think of mods to do to it lol.
IMG_2165.thumb.jpg.d54d72d08294c32adc40bd144d33a53c.jpg2014 Sierra SLT 4x4 with 3.5 Rough County with Toyo Open Country RT
Edited by Flflatsguy
2014 GMC Sierra 1500
Bilstein leveling kit on highest setting.
Fuel coupler 18x9-12
Bakflip cover
Morimoto fogs
Hid head lights
Not my shed
Edited by Btw64
Before and After
2018 Silverado 1500 Dbl cab LTZ 4wd
20x9 -12 Ultra 203B Hunter rims
275/65R20 Atturo Trailblade XT tires (Rub slightly at full lock on wheel well fabric)20180524_091705.jpg
Edited by Toallhisdoom
2018 All Terrain.  2inch leveling kit.  Would like a 4 inch lift and run 35s.
Looks good but You’d need more than a 4” lift to run 35’s, 6” and you may need to trim the valance.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,921 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
