How do you like the Westins? Do the steps line up well for getting in and out? I like those. Nice truck!
Rough Country 2 inch front level block, American Outlaw 20 inch wheels, 305/55/20 Nitto Ridge Grapplers, Westin HDX step down bars.
Love the silver on black! Sharp truck!
My 2017 GMC SLT: 6.5 inch suspension lift - RC Machined grill with 30 inch light bar, 20x10 Fuel Stroke -18 OS - Toyo 305/55/r22 ATii, Amp Research power steps, 2 JL Audio amps (500 / 700), Focal separates (front) focal full range (rear), 12 inch JL Audio sub.
  • Like 4
Nice! I wanna hear that stereo!
:) - Little over powered for such a small space, but JL Audio rocks for sure.. I'm not into the big bass sound, but the 12 inch ported JL Audio box does rock.
It’s a custom underneath the back seat box yah?
I just bought essentially the same truck last week...silver 2017 LTZ w/ 2LZ, but am just in the planning stages on mods. It has the OEM power retractable running boards, which I'll probably keep as I can't justify the expense of aftermarket retractables when I already have a pair that get close. Mild lift/level and bigger wheels and tires planned, same basic concept as you... I'm thinking something like 1" rear, 2.5" front (a little lift, a little level, and a little remaining rake) and maybe 33" tires on 20" wheels if I can safely make that work. Also deleting the front lip and replacing with a plate for clearance, clear bra the front end, improve the exhaust note, and maybe blackout the handles, rub rails, and hood insets.
On 2/5/2019 at 2:36 PM, sg.glover said:
Tire specs? Nice truck!
Thanks.  Falken Wild Peak 265/60/20
How you like that grill?  I've been eyeballing that sucker, that light bar throw off decent light?  Truck looks sharp!
Great pic. Same setup on all the trucks?
Thanks. Yes, 3 inch leveling kit and 33s. White truck has methods. Blue truck has the same Procomp wheels as mine.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,015 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
