Hey guys thought id throw this into the ring its a 3" leveling lift. I love it so far. Anything I should know? Also thinking of painting all the chrome glossy black :)
Edited by jnach
What size tires are those?
Sorry I didn't see this post. They are 22x9 with a 285/45/22 nitto terra grappler G2's They ride really nice and are quiet on the road
2.5 level with 275/55R20 Toyo MT's
D753997B-2363-4677-B757-32D7A56B18EB_zps
6D6D1080-1DA8-4655-AD13-46485ED9A8E8_zps
This looks awesome with the level and tire upgrade. I'm thinking of doing the same so I love seeing that it looks great.
Sent from my Nexus 6 using Tapatalk
Thank you! I'm really happy with how it's turned out so far.
Finished chrome removal and added painted fender moldings!
Do you happen to have a better angle shot of the painted fender moldings? I have Iridium which I fear may be too awkward of a color to match.
Sent from my iPhone
Sent from my iPhone
  • Like 3
Sent from my iPhone
The paint matched fender flares look killer in black.
Gotta say, this is probably my favorite visual mod I have done, much classier in my opinion than the dull plastic look.
Great looking truck, what wheels are those? Like them better than my LTZ wheels and seen them on one local truck.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
