Took the two day old truck with 300km on it and put on another 6000km over the last two weeks through Wyoming/Colorado/Utah and did some very light offroading (truck is stock Z71 right now) in Moab.
Wish I had gotten a couple more shots of the articulation in this one, the stance was opposite on the driver side with the left rear having about a half inch of clearance from the wheel well.
More to come, too many driveway and parking lot shots on here. :)
Edited by YEG
  • Like 4
A few months back I replaced my 2011 Silverado with a new 2014. I have been slowly adding things to give it my own touch.
So far I have put on the GM bug deflector. I had a Zone Off-road 2" leveling kit installed. I put on N-Fab textured steps. I installed a Timbren SES rear helper kit on the back end.
Soon to come will be a bedliner and I think tint to the front windows.
Here are some pictures so far.
Nice Truck Man I Love That color
Ha, putting the Allterrain to work i see! Not sure about using a turn signal in those parts, but congrats on the truck, it's beautiful!
Did you put that chrome wheel well trim on too or did you buy it that way? If i'm being honest, that completely ruins the look of your truck, otherwise, it looks awesome!
Picked mine up on Thursday. Put over 400 miles on it already. Quite a truck, even got a compliment from a random passer by in NYC! Here's the first time in the day light I could get both vehicles together. Both a little dirty but will do. I've had the CTS-V since '04. It was my daily for 7 years and has 150,000 miles on it. It is Stealth Gray and was the inspiration for the truck's color. juqemaje.jpg
  • Like 3
Grabbed this shot under the "super moon" bringing her home for the first time Saturday night. One of those times I really wished I had a decent camera around. edagy7uz.jpg
Sick picture! Congrats
Great looking truck and nice V. I had an '05 for a couple years, then sold it to my dad. Fun car.
Quicky from today on another job.
this is the guy that does the commercials for gmc lol
Sent from my SM-N900T using Tapatalk
Here's some more pics of mine I took this morning.
Edited by GMANsr
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
