How close does the red on the wheels match the victory red color?
Match is almost perfect right now
I was thinking about debadging my truck. Anyone have any experience doing this? I already have a 3m eraser wheel that I used on a previous vehicle.
Go for it! I finally figured out while pulling my side moldings off that parking it in the sun and a hair dryer with some dental floss is all I needed. No eraser wheel needed IMO (I was scared to use one on my new paint anyway).
http://www.gm-trucks.com/forums/topic/158148-remove-oem-badges/?hl=debadging&do=findComment&comment=1412309
http://www.gm-trucks.com/forums/topic/161996-tailgate-emblem-removal/?hl=debadging
Edited by Newm
I haven't de-badged the '14 (I kinda like the way it looks!), but I did on my '13. Just as Newm stated above, very easy with dental floss (or an old credit card), hair dryer to warm up the surface.
The most difficult part is removing the old adhesive. What I did, once I got the lettering off, was to soak the adhesive with Goo-Gone Gel, and let it sit in the sun for 10 minutes. Then take that old credit card and it should slide right off. Keep applying the gel and use a microfiber towel to do final clean-up with some good detail spray.
I'm with you on this. I've done it to all my vehicles in the past but I like the way the new 2014's look.
I thought I was the only one who thought this
Edited by KUUG
My '14 came from the lot with the Silverado on the doors, de-badged. All it has is the Texas edition emblem. I think it looks great. It still has the Silverado on the tailgate.
Outside my office
What kind/brand of taillights are those?
Anzo tailights, black color
Can you post a picture of the back? The pictures online don't look that dark.
SOLD! They look great! How's the visibility? And have you seen the Anzo Headlights?
post-131370-140554297178_thumb.jpgpost-131370-140554299273_thumb.jpgpost-131370-140554300584_thumb.jpg
I do have the Anzo headlights too. They're great.
Biggest POS I have owned. 2nd truck. Both had less than 5000 miles on them. Vibration in driveline. Buyer beware.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
