5 hours ago, C&L said:
 First day it came home to the next week. 2018 graphite metalic with pro comp leveling kit 33x12.50r22 toyo mt tires on 22x9 gloss black snowflake replicas.  Also had all the windows and windshield tinted. Debadged the whole truck and vinyl wrapped the front and rear emblems.
Great looking truck, though I prefer the original factory rims and tires over those new ones.
The factory's are ok jus to small. Especially after the leveling kit was installed.
New member here, here’s my 2014 sle z71 stealth gray metallic. Currently looking for help on installing amps and speakers. If anyone can point me to a good thread. And also maybe pics of your stealth gray with wheel and tire upgrades thanks
true..
Just installed some 295/70/18 Nitto Ridge Grapplers on my 2016 Silverado. Just a little trimming of the carpet and they fit nice.
What leveling kit are you running?
I’m running the two inch spacer from rough country in the front.
On 9/16/2018 at 2:35 AM, Stockredsierra said:
Sorry for the late response. I'll DM you.
Thank you. Method Race Wheels MRW301 "The Standard" 17x8.5 0 wrapped in Goodyear Duratracs LT295/70.
Thanks!
Looks good - what's the offset?
4 hours ago, theDeLo said:
New to me 2015 Midnight Edition!
Waiting on a leveling kit:
Welcome
Had a set of 34x12.50R18 BFGoodrich KO2's mounted on some Cragar S/S wheels today. This will be my winter setup, and before anyone asked 2" BDS leveling kit up front.
Edited by Crazy Schooner
Finally purchased and installed my cover. Ended up going with a Diamondback SE version. Was debating on the HD version but couldn't justify spending the extra $400. So far so good. Sits flush and so far no leaks. ANDDDD, as an added perk, feels like it adds just enough weight to the bed to level the weight on wheels....might be just my mind but still, pretty cool.  Can't wait to add the extra cleats I bought and start playing with the cover. As an added bonus to my already happy mood....come to find out....the bed extender works perfectly and fits perfectly under the cover!!
  • Like 3
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
