Nice Silverado!
Here is mine:
From the day I picked it up less than a week ago!
Edited by Dropsix
  • Like 8
Thanks guys.
24" Dub ShotCalla
295/35r24
Thanks looks great kinda making me think about lowering my truck a couple inches and put 24s on it lol.
Thanks. Yeah I need to drop the rear a bit. Planning on doing an airbag setup in the future. We'll see how that goes lol
Rme2513 I agree. I had 12 bags of overseed for my lawn and my back lowered down a few inches. If you add the block please post up some pics!
I've noticed that the new '14/'15 do not look quite as tilted forward as past models. I personally refuse to "level" a truck. There's good reason it's that way. But at least with the newer model, they've figure out how to not make it look that way so much.
I kind of agree. I feel like levelling these ones kinda make them lean backwards a bit, which looks odd to me. Like a 4 Runner. lol
Traded in my 2014 GMC 1/2 ton crew Z71 for this new Silverado LT 4x4. Added Black wheels, 275/60/20 A/T Tires, 2.25 Reddy lift on front and 3" on back, as well as bed cover, and Nerf Bars. Tinted all the windows darker, as well as changed out the red 4x4 decals to green to match my boat. post-125722-0-51691300-1414595817_thumb.jpg
Traded in my 2014 GMC 1/2 ton crew Z71 for this new Silverado LT 4x4. Added Black wheels, 275/60/20 A/T Tires, 2.25 Reddy lift on front and 3" on back, as well as bed cover, and Nerf Bars. Tinted all the windows darker, as well as changed out the red 4x4 decals to green to match my boat. attachicon.gifIMG_7324 (2).JPG
what brand wheels?
I like the trimmed valance. What did you use to trim it?
I used blue 3m painters tape to tape where the valance is creased. I then used a dremmel with one of the cutoff wheels to cut it. It actually melted quite a bit while I was cutting, which created a lot of edge cleanup afterwards with sandpaper and scuff pads, but you can't even tell at all, and I still kept some integrity in the front end/i.e gas mileage....
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
