Got rid of the 22s and put factory 20s back on with 275/60/20 michelin ltx ms2. Along with .5" spacers in fromt and .25" in back. The michelins ride perfect. And look pretty good too.post-124495-0-81485100-1415205134_thumb.jpgpost-124495-0-53759500-1415205147_thumb.jpgpost-124495-0-08066800-1415205156_thumb.jpgpost-124495-0-63778400-1415205166_thumb.jpgpost-124495-0-63845500-1415205178_thumb.jpgpost-124495-0-98315700-1415205189_thumb.jpg
Got rid of the 22s and put factory 20s back on with 275/60/20 michelin ltx ms2. Along with .5" spacers in fromt and .25" in back. The michelins ride perfect. And look pretty good too.attachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpgattachicon.gifimage.jpg
Looks good....
Curious as to why you got rid of your 22's? Didn't like the ride quality?
Got rid of the 22s and put factory 20s back on with 275/60/20 michelin ltx ms2. Along with .5" spacers in fromt and .25" in back. The michelins ride perfect. And look pretty good too. image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
Any rubbing? What spacers did u get?
Looks good....
Just thought it looked a little better with 20s and a level and not too showy. The ride with these michelins are definitely better than the stock goodyears and the stock 22s, which i was goimg for. But neither was super bad just not as good as these michelins.
Nope no rubbing but its close on thenpassenger side ever simce i put these new tires on. Just picked some up off ebay from a trusted seller
Heres is my current ride and here is my old ride
left truck my old summit white 2014 Denali 6.2L
right is new white diamond 2015 Denali 6.2L
picking up the 2015 Denali friday
Edited by White_Denali
Nice so you have two Denalis now? Any plans for the new one?
So you have 2 now or did the new one replace the old?
Why the wait till Friday if its in and you've seen it?
Sent from my iPhone 6+
who are you talking to? jw
My bad, I should have quoted. White_Denali
no trading in the 2014 denali on the 2015 one
dealer has to install some accessories as well as get the truck ready no inspection yet or anything
i did notice on the seat it said special 8 speed test from plant with a check mark wonder what type of test they do?
If you don't mind my asking, how much of a trade value did you get for your '14, and did you get any trade incentives? I'm thinking of upgrading again. My dealer doesn't have any 6.2's yet though.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
    • Just don't turn the steering wheel as much?
