How many miles between new brakes?
This is a question for all GMT900 owners, my truck has 70,000 miles and has gone through 8-9 sets of brake pads and a set of rotors.
Around 6000 miles ago I put top-tier Raybestos pads, and just yesterday I could've sworn I heard the wear indicator starting to squeal.
Is this normal? At this point I'm changing brake pads more often than I change oil. :dunno:
2007, original owner.
my 03 SS with 71k on it still has the factory pads/rotors. i think a lot has to do with driving habits. try going easy on the hard breaking :D and see what happens
Do you brake hard coming up to stop signs and lights? Do you tow heavy loads? Do you panic brake a lot? These would all account for your high pad usage
35K miles and still have original brakes. 8-9 sets in 71K miles. Thats like every 8K miles you change your brake pads?
I sold my GMT800 with the original front pads at 89K. Still had plenty of wear left.
I have like 54k on my truck, original brakes. What on earth kind of driving are you doing to change brakes as often as some change oil?
Like I said, I'm not hard on my brakes at all. I do live in a hilly city, but I downshift on steep down hills and generally drive calmly. I have probably driven it hard less than 10 times in the six years I've had it.
Lift your front wheels off the ground and spin both wheels. There should be a small amount of drag. Sounds like maybe your brakes are dragging more then they should.
If you are changing your brakes yourself, try having a reputable shop replace them. Just might be something simple you are doing wrong and not knowing it. Other than that, :dunno:
Holy sheep dip! This is not normal.
Normally I expect to do the brakes at 100,000 km = 60,000 miles.
My 2009 had 140,000 km = 84,000 miles and brakes still good when I traded it off.
Something is amiss.
My 99 had 186,000 miles on it and I never changed the brake pads on it, I looked at them when I put tires on it at 100,000 and they looked good but I pulled them off any way and could not believe how good they looked put them back on and kept driving it. Had a f150 work truck one time that had brake problems like that, when it got the oil changed it got new brakes and rotors every other time, the stock brakes went 28,000 miles and then it went to heck on that truck. We even took it back to the dealer and the first set of pads on it lasted 200 miles and they put a new set on and it was a little better but they could never figure out why it ate brake pads like it did. :jester:
something is wrong with your truck if you say your not driving hard... when i had a GMT800 1500 in hhighschool i drove it VERY hard on GM pads and they lasted about 50k
Are the pads actually worn down or are you just "hearing a squeak"? Are your calipers rusted to hell? Lubricating the caliper pins?
That is odd if your running stock wheels and tires. My 08 Sierra was chewing thu breaks and rotors as bad as yours is but I had those killing looking factory '20 wheels that were casuing my rotors to glaz and warp. I just did the breaks on my 2012 with 33k on the clock, the OEM still had some life but I wanted to get to them early to save my rotors. Plus I drive in stop and go traffic.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 634 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
