Bose Sound Quality?
I have always had aftermarket systems in my past vehicles. I am happy to say I will not be touching this system (Bose w/center console Sub) as its that good.
I would suggest to those that don't seem to like there Bose, must either A) do not have the center console sub (7th speaker) or B) have not configured the TONE (High, Mid, Bass) correctly or C) are still in the childhood phase where you want everyone to hear your vibrating woofers coming down the street.
I was looking to add an aftermarket sub to give it more thump until just recently I re-adjusted the TONE some more. Now the system rocks pretty dang good, at least for my needs.
Agree 100% I have the Bose system and it will rattle the mirrors if I turn the bass up to even 75%.
  • Replies 136
Coming from the 70s of Zepplin, and hard rock, Ive always went after market on my radios and mufflers, ( I have the lack of hearing as the results) with the quiet cab even the non Bose sounds pretty good.
It depends on who you ask, but I don't think I have the lack of hearing. But I'm also happy with the non-Bose and wouldn't consider changing it out. I'm sure there are some audiophiles out there who would cringe, but it sounds pretty damn good to me.
No issues. The system sounds pretty good to me.
Or D) came from a stock Ford F150 700 watt Sony system that absolutely blows this one away. The sub is under the back seat in the F150 and I could still hear it better and it was crisper. As soon as I turn this Bose one up past halfway, it becomes muffled and breaks up.
No complaint with the OEM Bose system in terms of sound/playback quality in my '14 Sierra Denali. That stated, the ever apparent radio reception is not great but since I primarily stream the audio source playback from either Pandora or Ipod its not something I worry about.
Or E: came from a competitive sound quality background and knows what really ****ing clean sounds like
If you're comparing the "stock" Bose (w/subwoofer) to a aftermarket sound system (especially competitive sound system) I think you're missing the point. For stock, the Bose system in a truck sounds impressive. Yes if you want go to a sound off contest it will get laughed at. But for sound quality of a stock system, tuned correctly for YOUR music it should hit the mark for 95% of most people.
And regarding the Ford 700 watt sony system I would have to disagree. But opinions are just that. If its "muffled & breaks up" after the halfway mark, you must be listening to some crazy **it or you may be part of the C) category. :)
I hardly think being 37 years old and listening to Dire Straits puts me in the C category.
Odd, Money For Nothing rocks in my truck. Tone adjustments include Treble 90%, Mid 35%, Bass 85%, Fade Center +1 toward Rear. Hope that helps.
This question is so subjective, what sounds great to one person sounds like garbage to another, unless you are talking about a very basic audio system, which the Bose is not.
i'm happy with my truck's audio but think I need to install a sub-woofer in my I-Phone
I would go with the large one, like the 1" by 1/4" deep woofer. I heard they're great ;)
    fourhorses88
    fourhorses88
  • Who's Online   4 Members, 0 Anonymous, 875 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
