Bose Sound Quality?
  • Replies 136
For years, I've gutted car after car, to completely replace the audio system. It's getting a little old (am so am I). While any stock audio system could never rival a full-on aftermarket set-up, I think the OEM Bose system in my new 2014 sounds pretty damn good. I have the center console with the subwoofer. I agree that the bass could be lower, but I'm planning on adding the Kicker Box w/integrated amp they now make for the new Silverado. I've heard good things about it. It should let me turn down the bass to the OEM sub and speakers; allowing them to play a little more cleanly while letting the dedicated SUB woofer play the extreme lows.
One thing I ALWAYS do to my vehicles is Dynamat the inside of the outer door skins, and I apply 1-2 layers of 1/8" thick "Volara" Sound-Barrier Neoprene foam to the back sides of the door panels. It makes a world of difference! Dynamat soaks-up and dampens vibration. The Volara foam blocks any road noise / sound from making it through the doors. Dynamat can't do it all.
In fact, I "say" I use Dynamat, but I've actually discovered a more mainstream product called "Peel-n-Seal" that is made by Cofair Products in Maryland...the same company that produces Dynamat, and it is a FRACTION of the cost. It is marketed as a window and door trim flashing sealer. It is a little thinner, about the same thickness as the original Dynamat. It is a Butyl Rubber / Asphault compound with a very powerful adhesive. I call it "Redneck Dynamat". I refuse to buy Dynamat anymore, as it is overpriced.
I've applied "Redneck Dynamat" to my last few vehicles, and it makes a world of difference! It sticks really well too. Hell, I applied it to the back side of my aluminum-skinned garage door in small sections, and you wouldn't believe how much quieter it is now!
Anyway, I like the OEM Bose system, but will probably add the Kicker Sub Upgrade under the back seat. I will also apply my Redneck Dynamat and Volara Sound Barrier foam to the doors to improve the already quiet ride of the Silverado.
The Silverado ride is so much quieter than my previous truck already, I am afraid I will not hear ambulance or fire engine sirens if I have the windows rolled up.
BTW, I also think the "sound stage" of the OEM Bose system is actually pretty good. Especially with live music. I am particularly pleased that the back door speakers actually sound good too, not muddy and washed out like previous models. I've had a Murano, a 350Z Roadster and an Avalanche all with Bose...and the Silverado sounds the best hands down.
Turn the Auto-Volume up to "High". Makes a world of difference
This added about 25% more volume on my RC, which was needed as I was maxing the volume out on the highway without it.
Rob - Could you supply a link where to see this new for Silverado, Kicker box+amp+speaker? Any idea where and how it installs. Thanks. Also if you do it, maybe you could do a detailed write up with photos etc. Besides me, there's probably 9 pages of people here who would appreciate it just as much. Thanks.
Jim
Jim
http://www.crutchfield.com/p_206SSIRE14/Kicker-VSS-8482-SubStage-8482-SSICRE14.html?tp=61674
It's called the Kicker VSS SubStage SSICRE14. The box specifically fits Silverados and Sierras. It works with Bose and non-Bose systems, and hooks into factory wiring. It's the perfect bass solution for someone who doesn't want to heavily modify a vehicle.
One 10" Kicker sub with a built-in 200Watt Amplifier. Crutchfield sells it for $699, but Amazon has it for around $575 I think with free shipping. I may ask "Santa" for it for X-mas LOL.
  • 1 month later...
The Bose system in my truck is sounding better to me now.
Not sure if it has broken in or what, but I also shifted the center balance point back a couple of clicks which has helped.
Initially I think the dash speakers were overpowering the system and the sound seemed to be coming out of the windshield.
By moving the soundstage back a bit the rear door speakers are providing more fill and the dash speakers don't overpower the sound.
I have also been using my own audio files on the SD card as a source vs the radio or that horrible XM.
(Wow I can't believe how much they compress the content on XM, sounds like listening through paper cups and a string.)
The only thing missing is feeling the bass notes.
The Bose sub in the console does a good job of extending the low frequencies but it doesn't make you feel any vibrations, only hear them.
Like when you have good headphones on, you can hear the bass notes in your ears but your body gets no other sensation.
My next upgrade will be adding a sub under one of the back seats, because otherwise the system sounds good. Debating whether a 10 is needed or if an 8" will do the trick. I'd like to be able to have the box under the passenger side seat so if I need to flip up the back seat I have more room available with the left side up.
is anyone running an 8" sub add on and can comment on the sound, and recommend some units to consider?
The kicker unit above could be an option. In the link it has some pictures, does anyone know what the picture of the under dash is supposed to be showing? I thought this was a self contained amp?
I think they sound great in my 15', they sound a lot better than the Bose in the 11' I had
From GM accessories:
AUDIO - ASSOCIATED ACCESSORIES
This Kicker® Powered Subwoofer and Amp audio system duplicates the musical accuracy of live concert experiences minus the crowds. It adds big-bass subwoofer punch in a small space along with high-efficiency low power-draw amplifiers and a unique sound signature from multi-channel amps with Digital Signal Processing (DSP). Non-GM Warranty. For details on warranty provided by Kicker® please call 1-800-256-5425.
Item Part No. MSRP
Audio - Kicker 200 Watt Powered Subwoofer Kit 19303116 $659.00
Audio - Kicker 200 Watt Powered Subwoofer Kit 19303118 $659.00
Audio - Kicker 200 / 400 Watt Powered Subwoofer and Amp, Double Cab 19303115 $1,059.00
Audio - 200 / 400 Watt Powered Subwoofer and Amp 19303117 $1,059.00
  • 4 months later...
On the 2016's you can get the 7 speaker system on an LT, see below.
From the "build your own".....
Bose® sound system
The premium Bose® audio system features 6 speakers located throughout the cabin for rich, clear acoustics. It includes:
  • 6-speaker system
  • Active Noise Cancellation system when ordered with the 6.2L EcoTec3 V8 engine and bucket seats
  • 7-speaker system with subwoofer when ordered with bucket seats
  • LT requires LT Convenience Package or All Star Edition
  • LTZ requires available LTZ Plus Package, Texas Edition or Sport
I will verify when I get home. I just picked up a 2016 LT Z71 with the Bose and I am highly disappointed. My 13 GMC 3500 Denali sounded way better.
big rog
My Bose sounds okay, but in my 08 Tahoe, it sounded awesome! It also had a console mounted sub, but it had much more low end base than the Sierra.
It there any way to simply replace the factory Bose 6" sub thats in the console with a JL 6" sub? I just want a little more bass, I dont need anything crazy
Bose® sound system
  • 6-speaker system
big rog
I checked and mine does have the amp on the wall behind the rear seat. Have to assume the subwoofer is under the console.
Have to admit Im kinda ticked that you pay an extra $500 for the Blose upgrade and it sounds the way it does. My Kia Optima has a factory Infinity system that sounds 10x better, and the whole car costs half as much as the truck did. And it came with heated steering wheel, heated/cooled front seats, heated rear seats, NAV, giant sun roof, etc.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
