Looking sharp sir!
Sent from my LG-D800 using Tapatalk
Between the color, wheels, Cooper tires and blacked out grille they had a lot in common haha.
I have money put aside for a new battery and a new monitor. The current battery is 3 years old. I still haven't decided which one I'm going to go with. As far as the monitor I want an Edge Insight, it can display 8 things at once.
As much as I liked the Scanguage, I wanted something that could display a few more parameters at once. The Edge Insight CS appeared to fit the bill. I got a used unit from another member. Then ordered the dash pod from Amazon to mount it.
086FB04A-32A1-4946-B563-DDD970E1F762_zps
The pod isn't a perfect match, but it's pretty close. The cable runs down the pillar, weaving it through the dash was the only slightly difficult part. The screen resolution is pretty good.
203BCCF1-92D4-424A-85D6-8D41D17992B5_zps
On the analog screen, you can set a custom background but it doesn't really matter to me since it will be on the 6 gauge screen.
F5CA1F35-A508-4277-A358-1B97E1F14955_zps
Overall it's a great unit and I'd recommend it. The only thing I don't like is the "power level" read out, which doesn't apply to my truck. It has a bunch of performance timers and economy stuff which I probably won't use much.
The Insight install turned out great man.
Thanks CA! It's a great setup.
I still need to try out more of the features.
The only problem is people keep asking me what kind of "tuner" I have. :lol:
  • 4 months later...
Last night I drained, flushed out, and refilled my power steering fluid. Really pretty easy. I had a DEF container and stole the spout from it. Used that to aim the old fluid into my drain pan. If you leave the cap on none will come out until you're ready. After that plugged it with a hose and bolt.
3CEFABE6-D08A-4EC0-807A-A0B3DB8BC965_zps
Aimed the return line down into the pan too.
3E296BCC-8C32-4E9D-9355-CFF7A2B59128_zps
I flushed it out with some cheaper fluid, then filled with this.
5EBE9C49-B84C-4338-A887-125994E9D001_zps
Made sure I got any air out and fired it up. I was getting a slight whine from it with the old fluid, now it's quiet as a mouse.
Thanks for the inspiration, I really need to do this.
x2
15,000 mile wear update on the Coopers:
They are wearing well so far. No cupping. They have gotten noisier but with the radio on 25% or more I don't notice it. We'll see this winter if snow traction is still as good. Dry pavement is about the same. You can see the first wear bars in the middle tread, not down to it yet. I would guesstimate 5-10k before they wear that far. I did a lot of gravel driving this summer and the tread has held up well as far as gashes and chunks.
C32AA28E-3357-4B09-BF5E-080F583D6B34_zps
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
