Looking sharp sir!
Sent from my LG-D800 using Tapatalk
Between the color, wheels, Cooper tires and blacked out grille they had a lot in common haha.
I have money put aside for a new battery and a new monitor. The current battery is 3 years old. I still haven't decided which one I'm going to go with. As far as the monitor I want an Edge Insight, it can display 8 things at once.
As much as I liked the Scanguage, I wanted something that could display a few more parameters at once. The Edge Insight CS appeared to fit the bill. I got a used unit from another member. Then ordered the dash pod from Amazon to mount it.
086FB04A-32A1-4946-B563-DDD970E1F762_zps
The pod isn't a perfect match, but it's pretty close. The cable runs down the pillar, weaving it through the dash was the only slightly difficult part. The screen resolution is pretty good.
203BCCF1-92D4-424A-85D6-8D41D17992B5_zps
On the analog screen, you can set a custom background but it doesn't really matter to me since it will be on the 6 gauge screen.
F5CA1F35-A508-4277-A358-1B97E1F14955_zps
Overall it's a great unit and I'd recommend it. The only thing I don't like is the "power level" read out, which doesn't apply to my truck. It has a bunch of performance timers and economy stuff which I probably won't use much.
The Insight install turned out great man.
Thanks CA! It's a great setup.
I still need to try out more of the features.
The only problem is people keep asking me what kind of "tuner" I have. :lol:
  • 4 months later...
Last night I drained, flushed out, and refilled my power steering fluid. Really pretty easy. I had a DEF container and stole the spout from it. Used that to aim the old fluid into my drain pan. If you leave the cap on none will come out until you're ready. After that plugged it with a hose and bolt.
3CEFABE6-D08A-4EC0-807A-A0B3DB8BC965_zps
Aimed the return line down into the pan too.
3E296BCC-8C32-4E9D-9355-CFF7A2B59128_zps
I flushed it out with some cheaper fluid, then filled with this.
5EBE9C49-B84C-4338-A887-125994E9D001_zps
Made sure I got any air out and fired it up. I was getting a slight whine from it with the old fluid, now it's quiet as a mouse.
Thanks for the inspiration, I really need to do this.
x2
  • 1 month later...
15,000 mile wear update on the Coopers:
They are wearing well so far. No cupping. They have gotten noisier but with the radio on 25% or more I don't notice it. We'll see this winter if snow traction is still as good. Dry pavement is about the same. You can see the first wear bars in the middle tread, not down to it yet. I would guesstimate 5-10k before they wear that far. I did a lot of gravel driving this summer and the tread has held up well as far as gashes and chunks.
C32AA28E-3357-4B09-BF5E-080F583D6B34_zps
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,532 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
