So how much does it cost to get V4 tuned out? Should I just buy a tuner and do it myself with a custom tune? Pros and cons on doing this would be greatly appreciated. Obviously a pro is eliminating any V4 drone, but what else is gained/lost by tuning it out?
Sent from my HTC One using Tapatalk
By tuning it out you could lower your MPG possibly. Also if the dealer sees that your truck was tuned then they can void your warranty. Sucks that they can finally tell when these trucks get tuned. I was gonna get mine done until I read that they figured out how to tell.
Get the range V8 device. It will eliminate V4 mode, installs in the diagnostic jack under the drivers side dash, easily removed and installed in seconds, can be left in all the time if vehicle is used as a daily driver, non-traceable when removed.
http://www.rangetechnology.com/pages/v8
Edited by 14LTZZ71
I just had my tune updated by Chuck @ https://www.facebook.com/chuckstuning he took out v4 but updated all my torque management and a few new A/F tricks and it feels great!!! BTW my mpg went up a bit on a 91 octane tune.
I would love to get a tune like that but don't want to void engine warranty. Yes, I'm scared to do it. LoL Edited by 14LTZZ71
I put a dynomax cat back system on my truck but the v4 done was way to annoying, so I swapped out the regular dynomax straight through muffler for the dynomax VT muffler with the "flapper" inside. I have to say it sounds much better and the drone is way down, I'm a happy camper.
Also at cruising speeds it doesn't even sound like you have exhaust, but if you punch it you release the V8 Beast!
I installed a Magnaflow 15565 (took it off my 2012 1500) yesterday on my 2014 crew cab 1500 with 5.8 motor. It installed with no problem at all, everything matched up except on the 2012 there was a extra hanger. I drove the truck around maybe 50 miles total yesterday after the install and everything seemed to work just fine, still dropped into V4 and the mileage seemed to be about the same. So for everyone wondering if the old system will fit and work it will.
Edited by SF Silverado
I installed a Magnaflow 15565 (took it off my 2012 1500) yesterday. It installed with no problem at all, everything matched up except on the 2012 there was a extra hanger. I drove the truck around maybe 50 miles total yesterday after the install and everything seemed to work just fine, still dropped into V4 and the mileage seemed to be about the same. So for everyone wondering if the old system will fit and work it will.
Very sweet never really thought Of trying gmt900 exhaust on the new trucks.... Good to know. Thanks man. Wonder if The old 6.2 exhaust fits the new 6.2's
Edited by Full Lock
To add on to SF Silverado. I bought a dual exhaust setup from one of the guys at work that he took off his 09 for $100. Took me about 45 min on my lunch today to pull it in my bay and put in. Has a flow master 80 and sounds so much better and definely a slight improvement in power
anyone with a 6.2 can tell me what size muffler inlet/outlet i need? Is it 3.5" like the last years? Im ordering a borla XR-1 15x5 for mine.
The stock muffler is 3” in and out. The pipe upstream is 3.5” but necks down right at the muffler, you’d probably cut off the necked down part anyway. Downstream the flapper right off the muffler is 3” but it necks back up to 3.5” pipe. Assuming you’re removing that as well, a 3.5” muffler is what it work the best.
This Friday Im cutting everything out from Y pipe back (including 3rd converter). Going with 3.5" pipe into an 18" magnaflow single in/ dual out right in front of rear tire with dual rectangle flat black tips like the old camaros.
Wtf lol Gm ****ed that one up. What's the deal with this flapper I keep hearing about? Whats it for?
Sent from Tapashit
Sent from Tapashit
I think it is supposed to help cut down on noise or anything similar in the stock exhaust when the truck cuts down into V4. But most of us are getting rid of it when installing aftermarket exhausts
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
