Does the front pipe have a valve and bypass pipe on it? If so, can you post a pic.
Here is the picture as promised.
Thanks.
The bypass pipe looks small but apparently it does something or they wouldn't put it there. Maybe it's there to ensure trucks up north start in the frigid winter months when the valve freezes shut.
I believe it has something to do with backpressure.
I think they calculated the exhaust pressure needed in order to open the valve in V8 mode, and when in V4 mode it closes and forces the exhaust around through the smaller pipe which maybe allows the pressure to be maintained within the down pipe reducing the drone.
Just a thought.......not exact science or engineering on my part.....
Edited by Strykers_Inc
I am highly considering getting the dual out the back Borla from Chevy....their part number and still has flapper for V4 mode.
Pretty sure I can get it at a discount from my dealer.
Have considered Gibson and Magnaflow, but feel a bit better about going with a GM endorsed part.
Just sold my 2008 Duramax, so just getting back into the gasser mode... :)
Has anyone done a straight pipe set up with a y pipe out to 2 tips in the back. Haven't seen this on a 2014 yet.
Getting the aFe installed today. I'll post pics and clips soon since no one seems to post much about this exhaust
I have the aFe installed and love it.. except the fart can tip that comes with it. I replaced it with a 3" in and 3.5" out dual wall mbrp tip after cutting the 3.5 flare off. Its a great sounding exhaust at a great price.
Edited by smpldezine
Does he tip that comes with it stick out too far or are you just saying its big?
Both..
That flare in the aFe pipe is where I cut it and added the different tip. The aFe tip in the kit is 3.5 in and 4.5 out... ok for a diesel, not a 5.3L IMO.
Check out this video from Borla.
At about 38-45 seconds it shows pictures of two exhausts and both show a flapper valve and bypass pipe just. Like the Borla systems you can purchase from GM...
I wonder if you can purchase directly from Borla now?
Borla will not sell you their system with the valve.
I bought their split rear exit behind each tire because GM doesn't offer that version. It had V4 drone and flutter so I contacted Borla directly and asked if they would send me just the front pipe assembly w/valve and was told "we will give you a full refund and then you can go buy the GM version" " we can not provide you with the front pipe assembly that contains the valve, this belongs to GM".
So I took the refund, I think they wanted my exhaust to test anyway, at least that's the vibe I got from our conversation.
You can get the Borla for around $900 and the GM version cost $1250
Edited by 14LTZZ71
Has anyone considered cutting the valve out of the stock system and then having it welded into a new cat back system on the inlet side like the a Borla GM system...seems you could end up with the same thing minus the small bypass pipe on the GM product.
You do realize that these exhausts are tuned....as in frequency tuned... Just adding a valve more than likely will not stop the drone.... Notice the valve being before the muffler on the GMPP Borla... There is a reason there is a bypass pipe.... The stock muffler valve is in my opinion to blowout excess back pressure at startup...
Yes, I realize they are tuned.
In this video Jeff Luke, Executive Chief Engineer for the Chevy Silverado talked to www.drivingthenation.com about passive flapper valve.
http://www.drivingthenation.com/lou-ann-hammond/chevy-silverados-passive-flapper-valves-and-more/
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
