You've had good luck with flowmaster? I've heard bad things and good things so it's hard to tell what to believe.
I've just had them last a long time in my '98 which was beat to death on and off-road. It came with a couple Flowmasters already on it (got it used), just not sure what series they were. They looked like they had been on the truck since new since they didn't look nowhere near new when I got the truck. Well they lasted for the entire time I had the truck and the truck saw a ton of mud. The only reason I had them replaced was because a lot of the factory pipes and whatever tailpipes that were on it rusted out so I just had a good portion redone even though the mufflers themselves were still in solid condition. Part of that was just me wanting to also at least know what mufflers I had so I had them replaced with the rest of the pipes.
It's just like anything else including these trucks in general. Some people will have good luck with things while others will have bad luck. Nothing has happened for me to make sure to go away from Flowmaster so I'll stick with them. I'm not trying to sell Flowmaster to you, you get whatever brand you want, I'm just saying I haven't had any bad luck with Flowmaster and being that I'm brand loyal with everything I'm going to stay with them unless their quality goes into the dump and go off just their name to sell products.
I've always used Flowmasters on my past 2 trucks (Super 40 and Super 10) and put a 14" Maganflow on my '15 about a month ago. Never had any problems with Flowmaster at all and they sound great, specially that 10 - sounded like I had a cam on idle and would scream when you got on it lol! Magnaflow is quieter but I think has a more quality, solid deep sound, probably due to the "acoustical packing" where as Flowmaster uses baffles.
Can't go wrong with either IMO and about the same $
Edited by Cohen
Well said....it's all about the sound you want. I have nothing bad to say about FM, MF, Borla. I've ran them all (on multiple vehicles).
Listen to sound clips on youtube, but just make sure you're listening to the same vehicle style or exhaust components.
Oh, and the MagnaFlow 14", I ran that on my 6.0 and it sounded good.
I will second the 14" Magnaflow. I have one and love it!
Here are some videos of mine.
I did a 14" Magnaflow with 3" pipe all the way out from the Y and cut the 3rd cat
What size is the stock piping? 2.75 and the 3" muffler just slid over it and was welded in place?
The Borla being 3" in and out, accepts 3" piping into the inlet/outlet. So, what is done is that a 3" piece is put into the inlet and outlet and then cut to the length needed. Then that 3" pipe inside the Borla inlets and outlets is slid over the stock 2.75" pipe and welded.
I'll attach a pic so you can see it.
The outlet (left side) the 3" piece of pipe is in the Borla outlet, but only didn't extend out, just put it in there to snug the 2.75 and make the weld easier.
The inlet (right side) the 3" piece of pipe is inserted into the Borla inlet and then extends to the factory 2.75 piping where the muffler was cut out and welded on that side (along with the weld at the borla inlet to insure no leaks).
Edited by Rawyzf
I see what you mean now! Are magnaflow mufflers like that too? Where they are made for the 3" to slid into it?
Yup, if the muffler says 3", it means it accepts 3" piping. (at least all the ones I have dealt with).
Every manufacturer has a page like this, it will explain the different muffler styles they have and then the sizes they offer.
https://www.borla.com/products/mufflers/index.html
I know the Borla XR-1 is more of a race muffler, where as the Borla ProXS is more of a touring muffler.
Edited by Rawyzf
Sweet, thanks for the help! I'm going to hopefully pick something out soon.
NP, take your time and listen to videos and find what you like.
Another option I just though of, is Volant. It's pretty much Corsa, with cheaper grade steel. I don't think you can get a muffler only though, but the catback is fairly reasonable. It has really good sound, you can ask txjose about that.
http://www.autoanything.com/exhausts-mufflers/volant-exhaust-systems
I think I've narrowed it down to either the Borla xr-1 or magnaflow race muffler. Can't decide, they both sound great.
Anyone familiar with the Gibson Metal Mulisha exhaust for 6.2L? If so what's the deal with the 4" piping? Sounds good as far as I can hear on YouTube just not a big fan of the exhaust tip but cant beat the price. I've used Corsa sport on 2 prior vehicles and still looking for that sound level but don't really want to pay the 1k price tag.
Does anyone know if the Stainless works exhaust is good? I heard a couple of video clips and it sounds pretty good to me.
SW is a very good well known company. Everything I have seen has looked and sounded great. They are just a tad on the spendy side, but you get what you pay for.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
