Will somebody let me know what the torque specs are for the rear shackles on a 2014 Siverado LTZ?
When I searched for 'torque', I found posts that said "torqued to spec", but nobody has posted what the spec actually is.
Bumping my own post.
Also need the specs for the U-bolts.
Went to my dealer yesterday and a very nice mechanic looked up the specs for me.
Rear Spring Shackle Nuts: First Pass = 85 lb ft. Final Pass = additional 90 degrees.
Rear Spring Anchor Plate Nuts: First Pass = 59 lb ft. Final Pass = additional 130 degrees.
Lowered my truck with two inch rear lowering shackles,installation straight forward,no problems with ride or drive pinion . I'm glad I did this modification .
Edited by rcmike
I've removed the blocks in the last 3 GM trucks I've owned using stock U bolts and nuts with "zero" problems. It levels the truck nicely. I just had to lower my headlights a tad.
Couldn't get the bed seams laid over far enough to get top bolt out. Ran out of time............
Try again another day
It took me a while also. I also loosened the bed bolts also to give it some give when I was knocking the bolt out. After I removed the bolt I cut off the bolt lip on the head so it would be easier to knock it back in.
Would it be possible to get a direct side view of your truck,by the the look of the pic. the stance of your truck looks perfect but I would like to see a direct side view if you have one ,just to verify the picture is just with the factory blocks removed correct?thanks
Edited by Tqjunkie
I put a set of 2" lowering shackles on the back of my 2014 denali, drives great until I hooked my trailer to it (approx. 2000lbs)
Got a bad vibration that gradually gets worse up to about 110 kph.
I'm thinking it needs shimmed but I just wanted to see if anyone else has run into this.
Here is My 2014 Sierra. Lowered 2 in the front 6 in the rear
Stock the day I bought it
After the drop and painted Grill
After 24's installed
What did you do to get the 6" in the rear?
Its a rough country lowering kit. It says 5.5 inch in the rear and for whatever reason it ended up being 6 after it settled. Its a simple flip kit in the rear
I like those rims! What brand/model!!
Nice looking truck! :)
Has anyone who's played around with u-bolts ever seen them loosen up after a few hundred miles or is this more urban legend than sound engineering?
Yes, more then once.
I can name 3 trucks that I or my friends lifted and had the u-bolt loosen up after a few hundred miles.
I always recheck them.
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
