Will somebody let me know what the torque specs are for the rear shackles on a 2014 Siverado LTZ?
When I searched for 'torque', I found posts that said "torqued to spec", but nobody has posted what the spec actually is.
Bumping my own post.
Also need the specs for the U-bolts.
Went to my dealer yesterday and a very nice mechanic looked up the specs for me.
Rear Spring Shackle Nuts: First Pass = 85 lb ft. Final Pass = additional 90 degrees.
Rear Spring Anchor Plate Nuts: First Pass = 59 lb ft. Final Pass = additional 130 degrees.
Lowered my truck with two inch rear lowering shackles,installation straight forward,no problems with ride or drive pinion . I'm glad I did this modification .
Edited by rcmike
I've removed the blocks in the last 3 GM trucks I've owned using stock U bolts and nuts with "zero" problems. It levels the truck nicely. I just had to lower my headlights a tad.
Couldn't get the bed seams laid over far enough to get top bolt out. Ran out of time............
Try again another day
It took me a while also. I also loosened the bed bolts also to give it some give when I was knocking the bolt out. After I removed the bolt I cut off the bolt lip on the head so it would be easier to knock it back in.
Would it be possible to get a direct side view of your truck,by the the look of the pic. the stance of your truck looks perfect but I would like to see a direct side view if you have one ,just to verify the picture is just with the factory blocks removed correct?thanks
Edited by Tqjunkie
I put a set of 2" lowering shackles on the back of my 2014 denali, drives great until I hooked my trailer to it (approx. 2000lbs)
Got a bad vibration that gradually gets worse up to about 110 kph.
I'm thinking it needs shimmed but I just wanted to see if anyone else has run into this.
  • 1 month later...
Here is My 2014 Sierra. Lowered 2 in the front 6 in the rear
Stock the day I bought it
After the drop and painted Grill
After 24's installed
What did you do to get the 6" in the rear?
Its a rough country lowering kit. It says 5.5 inch in the rear and for whatever reason it ended up being 6 after it settled. Its a simple flip kit in the rear
I like those rims! What brand/model!!
Nice looking truck! :)
Has anyone who's played around with u-bolts ever seen them loosen up after a few hundred miles or is this more urban legend than sound engineering?
Yes, more then once.
I can name 3 trucks that I or my friends lifted and had the u-bolt loosen up after a few hundred miles.
I always recheck them.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 846 Guests (See full list)
