Does anyone tried these Belltech Lowering Shackles Part #:6401 or 6400 on 2017 2500/3500hd? I called them an they said they don't make shackles for 2500/3500hd just for 1500. :nonod: Can someone share a link for the right shackles for my truck. 2017 2500HD. Thanks
http://www.belltech.com/belltech-07-17-chevrolet-silverado-sierra-1-2-ton-all-2-or-3-rear-drop-6401.html
I'm limited on ways to lower a 4x4. There's no spindle that works on a 17 4x4 otherwise I would've done that with the djm arm
Inez is working on a setup for the 4wd Silverados. Started a few weeks ago on the design.
whats the difference between spindles from 2015 and 2017?
Probably size and shape to accommodate the axles and extra strength needed. I'm 2wd so not completely sure. The Inez kit will most likely be arm replacements but won't know for sure until they get put into production. I'm sure if you're near SE Texas you could drop by the shop and sneak a peak. :D
Chevy was not awesome and made 3 different spindle types. 07-16 (some 16s) have cast steel spindles. Some of those years also had aluminum spindles. From 16.5 on tbey went to a stamped steel arm and hd ball joint
I would love to be able to do that, unfortunately i am in Middle of Nowhere W.V. As soon as i say i want to lower my truck, people freak out.
:help::help:
What about shackles? Are they also different? Cant find one for 2017 2500hd 4x4 z71 :dunno::banghead::fume:
I would call the shop and ask. They do custom arms, blocks and shackles.
Edited by Goinovr
Finally got the Sierra Denali lowered with DJM 3/5 kit.
Lowered control arms in the front and flip kit in the rear.
26"x10" +31 offset GMC Sierra wheels.
Borla ProXS dual exhaust 3.5" oval tips out the sides.
Recon black with LED halo headlight.
LED tailight, LED 3rd brake light.
LED fog lights (on order).
Blacked out GMC grille emblem. Rear emblem not installed yet.
Working on component speakers/sub box/amp/DSP install next.
Edited by Denali2low
IHC just posted a 4x4 silverado with their 4/6 kit. Guess there is no difference in arms since it's the same as the 2wd kit.
FB post...
22365230_1451523268270160_85471850852501
Edited by Goinovr
I wanted to chime in here as well.
2014 Silverado DCSB LT Z71 4WD.
Really wanting to lower it at some point. I've looked at every possible kit for these trucks and just not sure where to go with it mainly because of the fact that it's 4WD. I know there's companies out there making stuff for the truck, but when you're like me and have never done suspension work or even lowered a pickup before, things can get a tiny bit overwhelming pretty quickly.
I planned on starting out on either an easy 2/3 drop (while upgrading shocks and struts since the ranchos have 70K+ miles on them now) to get a feel for how I'd like having the truck lowered, and possibly going to a 3/5 or 4/6, but biggest things I'm concerned about are the driveshafts and CV axles (All of which really ought to be upgraded since I would like to go faster, but that's a different topic for a different area of the forum) and pinion angles, etc. All that fun stuff.
Am I really making it out to be that hard in my head, or is there honestly more to it?
Forgive me if this has been long since discussed. Trying to dig through 106 pages of posts is going to get tiring quick. So, I do apologize if it's been discussed. I figured it'd be easier to reply here rather than start a new thread.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
