On 2/2/2019 at 8:04 PM, lovelessjl said:
Word of caution, you'll have to cut the lower balljoint stud to run 20s, otherwise you'll have to go with 22s or larger with the mcgaughys spindles
I have a 2014 with McG spindles and didnt have to modify anything to run my factory 20's.  When I installed them I believe they said anything lower than 17's would require you to cut the balljoint stud.  I definitely had enough room to go down to a 17".
I finished up the front of my drop today it’s about a half inch lower in the front and back on the passenger side. If I add a ring to the passenger front side will it raise the back a little also?
Thats very strange. Usually tbese trucks lean half inch to the drivers side.  It will lower the oppsite side rear a little. Teeter totter effect
Ya that’s  what i always thought. But I know mine always leaned more towards the passenger side even when it was stock
Take a ring out of the drivers side
I only have the big ring in on both sides
You have the belltech struts?
Ya
Ok thats why. I have mcg. They go 3"
I might have to switch out my rear shocks also they are pretty damn stiff. They are they Belltech SP shocks
Those are the ones you want for a 4 door
But id look into some vikings with shock extenders. Only thing is you have to do a little grinding on thr extender to clear the shock body
I put a small ring on the left and no rings on the right
That’s what I’m thinking about doing is just not running any rings at all on one side. You haven’t had any problems with yours?
no problems
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
