Hey guys,
I think I have decided where I want to start with my lowering. I hope to order spindles for the front, and 2” lowering shackles and remove the rubber block between the leafs and the the axel. Should be about 2/3.5ish. Should maintain a little rake when empty and level out when I have my bike in the back ?
will I need new, shorter bolts for the leaf springs and what about shock extenders? Anything else I am forgetting?
Thanx,
Krunch
Hey guys,
I think I have decided where I want to start with my lowering. I hope to order spindles for the front, and 2” lowering shackles and remove the rubber block between the leafs and the the axel. Should be about 2/3.5ish. Should maintain a little rake when empty and level out when I have my bike in the back [emoji41]
Thanx,
Krunch
Belltech kit comes with spacers, I think it's part #6401. I have a 17 crew cab and it dropped mine exactly 3". My 14 crew cab only dropped 1.75" with 2" shackles. The block b/w the axle and springs is 1.25". Fender height on my 17 is within less than 1/4" all the way around.
Sent from my Pixel using Tapatalk
I was leaning towards McGaughys parts. I think I read something about having to cut a nut or something on the Bell spindles?
Was also considering ordering new, shorter bolts to eliminate spacers completely.
Do I need shock extenders and different bump stops for the rear drop I am planning?
Thanx,
Krunch
Thanx,
Krunch
You dont need shock extenders for 3 inches. I did the 2 inch shackles and flipped the block for 3 inches and didn't need anything.
Thanx,
Krunch
If you have 4 wheel drive then you'll need to trim the upper ball joint stud so it's flush with the nut. If you run smaller than 20" wheels you may need to trim the lower balljoint stud. I would recommend shock extenders. It'll help keep your shocks in their operating zone. As long as your u bolts don't show any signs of deformation I would say they're OK to re use. I would change them if you remove them a second time though.
Ii have 4WD, I have 20” stock rims and winter tires for winter, and just bolted on the 22” summer rims and tires. So I don’t need to trim any studs?
would consider reusing the bolts but I would also need to buy spacers anyway right?
thanx,
krunch
Edited by krunch
Flipped the block? I thought it got deleted?
thanx,
krunch
thanx,
krunch
Yes the shop that did the work flipped the block from under the leaf springs to on top or vise versa can't remember which way but it also gave me 3 inches in the rear.
Hmmm... I think I understand what they may have done, and doing this may have eliminated the need for spacers on your bolts. If that’s what they did, I wonder if they added some sort of plate between the top of the rubber block and the u-bolts so the bolts wouldn’t squat into the rubber?
thanx,
krunch
thanx,
krunch
You will need to trim the top stud for sure. It's to make room for the cv axle. You might need to trim the bottom stud to fit your winter set, if you do just removing the unthreaded portion will be plenty. Your 22s will clear fine.
thanx,
krunch
The block isn't rubber, it's steel and nothing to cut. McGaugheys and Belltech shackles are exactly the same. You could relocate the block to avoid needing spacers, but not sure what that involves. May have iterference with the spring stud.
What about bump stops? Will I need to replace or modify the OEM ones?
Thanx,
Krunch
Thanx,
Krunch
Not for 3", I've had no issues. Actually rides better than stock to me. I don't pull a trailer or haul anything though.
I only plan to throw a few pieces of lumber in it every now and again or my bike which is about 500 lbs.
Thanx,
Krunch
I am new member to this forum and I have a question about lowering kits. I've read all the way back to page 146 and it seem like the best way to go is either Belltech or McGaugheys for a 4/6 drop kit on my 2014 Crew cab Silverado. I have the opportunity to purchase a INEZ 4/6 lower and upper A arm flip kit for a very good price and its tempting. What are the pros and cons with this kit. Should I stay away from this kit? Thanks
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,225 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
