I just got a pair of the Twisted Metal Workz UCA's delivered.  Take the truck in next week to get them installed.  I only have drop spindles but the wheels sit quite a bit back in the wheel well and my 22's rub and most turns.  I can't wait to get rid of that problem.  Part of the reason i was think about the struts and shocks was thinking about getting all of the work done at the same time.  Thanks again.
Do you have a DJM or IHC kit installed?
I originally had the IHC with the lower control arms only for a 3"/5" drop but didn't want it quite that low partly because it was a touch lower than I wanted but mainly because it rubber a lot.  I chose the kit because the front wheel was not supposed to shift backward, but in my case that was not what happened.  IHC tried to make it right and even sent me a second set of arms to fix the problem.  It didn't change the wheel position.  So at that point I followed Nasty's advice and changed the arms back to stock and put in a drop spindle.  The wheel position improved a small amount but not much.  The turning radius/rubbing problem improved to a tolerable level.  Since Nasty mentioned the TMW UCAs though I have been hopeful that they will improve the wheel position enough that I might get back a large amount of turning radius I lost.  When I talked to the mechanic doing the alignment he said it was the stock UCAs that were limiting the wheel position.
Ihc kits shift the wheel back more than any other kit
Sent from my SM-G975U using Tapatalk
My wheel shifted a lot with either their lower control arm only kit or a drop spindle.  The spindle was less but not much.
I've never had that issue with just a spindle.
Well apparently I am the exception because my wheel is quite a bit back.  The stock UCAs are adjusted as much as they can be and it is still back a lot.  Is there a way that the spindle could be installed wrong to cause this situation?  Not sure if the picture does it justice but this is post spindle.
This is with 4 inches upfront. The wheel moved back about an inch or sob8340447bc99c4a96d372eeb61d16d16.jpg583b137b956a2cfbfd332ba0e49922d7.jpg
6 minutes ago, Nasty said:
That looks stock
Its not.  Picture isn't doing it justice.  Rubbing is only along the rear of the wheel well and occurs with just over a turn and a half.  Besides if it were stock then the IHC wheel movement was basically the same.
That looks a little better than mine with only a 2 inch drop upfront.  Your driver side looks better than the passenger side in the pictures.  Is that what you see in person?
Mine is the same. Drivers is less
When it was at 4 upfront yeah that's how it looked in person, since then I've moved up to 3 inches because the rubbing was bad. I refused to go with a smaller tire and I've never really checked the gaps ever since tbh
Will the TMW UCAs fix that difference?  My alignment tech said he couldn't move the wheel any farther forward because the stock UCAs didn't allow it.  I ordered the TMW UCAs after seeing your endorsement of them because they are more adjustable.
Looks like you are running the 20" rims with standard tire size, correct?  I have 22's with 285/45 tires (stock tire size for these OEM rims).
Yes correct.
    520Zilla
    520Zilla
  • Who's Online   4 Members, 0 Anonymous, 506 Guests (See full list)
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
