Got mine last week. Still waiting on the steps to arrive, hopefully tomorrow.
they are the same exact paint code. it has a purplish base. depending on the painting it can go from purple to grey hues. I ran into that with my leer cover. they painted it with the more grey base and it didnt match my truck which is more of a purple base.
Same exact problem here. Leer must not have it quite figured out right.
I refused to accept it and sent it back to leer with my tailgate panel to be repainted. I expect it to be in this week. If not right the second time not sure what I will do.
it was waaaaaay off though. not even close
ya it never made it on the truck and the place I bought it from sent it to a place in town to be repainted with someone elses iridium gas cap haha. Got it back on and matches a lot better now that leer didn't paint it, a tad off but not anymore than a person would expect it to being aftermarket paint
leer offered to paint it or have a local guy paint it with a max $300 payout for me. I figured id let them do it again vs a local painter, I wasnt going to pay for the cover until it was right or pay any more if it went over the $300 mark. I pick it up tomorrow, we shall see.
guy says it matches the tailgate panel so hopefully its right
got my leer cover on today. much better paint match this time. depends on how the light hits the angles but its matched pretty good, unlike the first time
so new cover came in, much better match job on the paint second time around. Will post some pics once I wash the truck lol. she's dirty :D
I got mine a couple weeks ago. Traded in my '13 LT for a '14 Tungsten Metallic LTZ Z71 on factory chrome 22's... Love this truck!
  • Like 6
Here is mine still at the dealer. I wanted leather and a bed liner added so it is another two weeks before I can get it. I am still driving my 2010. I can't wait to get it!
Just picked up my new truck yesterday from the dealer. Tungsten Metallic was absolutly the right color choice! Had no idea how 'purple' the base coat looks in the sunlight. Beautiful.
you really dont know until you throw a grey tonneau cover on it lol.. then it looks really purple lol
glad they got it painted right though
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
