I'm new here, just ordered a 2014 Denali 1500 Crew Cab. Looking for advice on a good weatherproof tonneau cover, preferably a soft roll up.I have a retractable one on my Silverado LT but it takes up room in the box. Hoping to find one that I can throw my luggage in the back on my trips to Florida and everything will keep dry in the rain. Also want something that can't be easily broken into.
Thanks,
Gary
P.S.
Pretty cool site you guys have here reminds me of LS1.COM when I bought my SS Camaro. Did some great group purchases there.
I had an Access tonneau cover on my 2008 Silverado and it always kept everything dry and clean. I will probably go the same route for me new truck as well, unless something there's something new that really has something new to add (no clue what that would be though).
I had a soft tonneau cover on mine, came with the truck when I got it. I was a pain in the neck to take on and off. I got sick and tired of that and just picked up a really nice tool box instead. Much much better! A lot of room for all my stuff, locks, and I still have my bed open for hauling stuff. Win win situation in my opinion.
  • Like 4
I have an Access soft cover on my 2006. It works good. But if I was worried about security I'd go with a hard cover. Anyone with a pocket knife can open a soft cover.
I just got the bakflip vp. Looks like soft cover but it's a hard trifold. Very water tight. Locks down well.
It's also easy to take off. FWIW
I have an access roll up and it works great for my needs. I bought one in 2006 and used it until buying this truck and it was still in excellent shape. The tonneau material, weather stripping and single release for both sides are improved from 2006.
Is access the brand name? Also can you please help me with something? I just read that there are no AC or Heat ducts to the back of the Crew Cab Denali I ordered. You have a 2014 Denali Correct? I ordered black and have a huge concern because I drive to Florida 2 or 3 times a year, worried about whoever is in the back will bake.
Some also told me the only heat or cooling comes when the heated or cooling seats are on, is this true? I can't test it at my dealer because it's only in the 20's here in Pa.
Thank you very much,
Gary
Bakflip F1 folds all the way up to cab if needed, Got up thursday morning to 14 degrees, 10 min warm up and drove 265 miles no complaints from back seaters about being cold at all, actually had the ask to lower the temp. running 72 on auto climate
Thanks,
Gary
P.S.
If you want weather-proof, roll-up, and secure, then you should look at the Roll-X made by BAK. It's exactly all of those three things :). It's at the top of my list (awaiting delivery of my '14 Silvy!) and the other contender is the Bak-Flip VP (same vinyl appearance as the Roll-X, except a tri-fold design instead of roll-up).
In either case, they're designed to be secure (as secure can be), and from everything I've read, do very well at keeping water out.
I have the Extang Trifecta Signature Series. It takes about 2 minutes to remove the entire thing and about 5 minutes to put it back all by myself. It stays dry under there too.
Sent from my SCH-I535 using Tapatalk 2
I have the Truxedo low pro qt as well. Real nice low profile cover. Easy to put on and take off. Snaps into place and is released by one handle on the back drivers side. Also has two spring loaded tensioners on the front that can be adjusted for tightness. The Velcro on each side slides with the tensioners, which is very good in my opinion. Best of all it has a life time warranty on everything as long as it is bought new and not second hand. Oh and you can also put box rails on the bed if you choose with this cover as well. Works and looks good on my 14 gmc sierra slt z71.
I installed the Undercover Flex today on my truck. I like the looks and the fit and it only took about 30 minutes to install. It was $665.00 shipped as I mentioned others got it for that price, and they honored it. My old cover on my previous truck was aluminum, and I wanted something that might hold up better in hail. No idea how bad it leaks yet, but from the looks it shouldn't be bad.
Now I am waiting on the Bedrug (Chevy logo one) to be delivered, so it can be installed. Than the bed should be done...
What do you guys think about the gator and tonneaupro covers? They run about $260 shipped in roll up and trifold...
Sent from my Nexus 7 using Tapatalk
    DM22
    DM22
  • Who's Online   6 Members, 0 Anonymous, 1,706 Guests (See full list)
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
