Roll n Lock or Rollbak G2? Any comment or recommendations? What about durability, water leakage, dust leakage, the fit, etc. Thanks.
Edited by MotoMedic
New member and I thought I would get started with my first review of the Extang Solid Fold Tonneau
PRICE:
I purchased from Zig's Auto through Amazon for $689 with free shipping ($310 less than retail). I ordered late Thrusday night, it shipped via FEDEX Friday afternoon, and was delivered this morning.
INSTALLATION:
I unpackaged and installed in 10 minutes unassisted. Cover is very solid glass filled aluminum clad but weighs in at less than 50 pounds. I could have installed faster but I was picky on the positioning. The design is extremely simple and attaches by the cab with a single clamp on each side using a large wing nut to tighten without the need for tooling. True bolt on with zero modifications (no cutting or drilling)to the truck.
Fit:
High quality product with great fit and finsh. I will post up later after it goes through the car wash/leak test. At first I thought it would have been nicer if it were about 1" longer and then I realized that it would not work as the tailgate would wedge against and lift the back end up while openning.
Looks:
Tastses vary but I really like it. The cover looks like it is supposed to be on the truck and not an afterthought that was scabbed on.
Pros / Cons:
The feature I like about ease of installation and removal also means it can be stolen in less than 2 minutes wit an unlocked tailgate. I recommend you keep your tailgate locked while your truck is unattended!
Edited by MotoMedic
Various pictures. Please pardon the frozen suds from the car wash
Edited by scphilli
Very informative thread. I ended up going with the Extang solid fold. Impressed with initial quality and fit. Tie will tell if it holds up.
Anybody have a Retrax bed cover or know of any that does? Feedback is appreciated.
Edited by MotoMedic
I'm not a fan of them, because you loose valuable box area up front. That 8 inches or so is pretty important when hauling some things, and wanting the tailgate closed. I will be going with the truxedo for that reason.
Mine will be a standard length bed, so I'm not too worried about that lil bit of space loss. I like the idea of the retractable covers and these look like some of the nicest and most durable ones on the market. Sealed bearings, durable construction, limited lifetime warranty. Sounds like I've already made up my mind. LOL.
These things look sharp! Anybody have one or know of any that does and care to give some feedback is appreciated.
i have a retrax one. For about two weeks. So far so good no complaints.
Sent from my iPhone 5s using Tapatalk
I have one for my truck. They make two different kinds. One a Retrax and the other a Retrax Pro. I got the Retrax which is the less expensive one and had them punch out the holes in the Retrax rails system to match the truck bed rails holes in the truck. They did this at no cost. This way I could use more options without the Retrax system being in the way.
http://www.retrax.com/
Another system that doesn't have a canister is the following:
https://www.peragon.com/features/easy-installation.php
Either way I like my Retrax and had it for about five months. My sister had hers for over two years and I never heard of a complaint about it.
I'm assuming you ordered direct from Retrax to have the modification to the rails performed? What other bed products do you use with the modded system?
Yes, you or the place you order it has to be completed by Retrax. It is a direct order and has to be requested at that time.
I have the solid fold on my 2014 . I think the cover is worth getting . It does let some water in the bed when it gets washed but not enough to cause any promblems .
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,951 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
