You don't use the jump seat harness to power the front ports. All you do is buy T connectors and jump power from the front 12v to the other. Yes you can run a dedicated line if you like but not needed. The only thing that will not work are the 3 USB ports. You can get them to charge only but I just left them I don't use them anyway.
Posting this pic hoping it helps someone. This the connector from the new full length console. It should be self explaining. Multi colored wire on left goes to Rear Cig 12v outlet, the multi wire to the left of it goes to inside console Cig 12v. The large black wire is ground, The white/brown wire is the console light. All the other small wires connect to the usb ports inside console & sound port in console. The mini USB is one black wire all to its self as marked.
Is that a 2016 console? What part number?
Sent from my BlackBerry Priv. The power of Android combined with the security of BlackBerry.
I ordered #22995069 Black Console. However, they sent #23466980 Black Console because the #'s have updated & changed.
Tried to do this from phone but had to get to computer.
Edited by Rocky Ridge
I ordered #22995069 Black Console. However, they sent #2346680 Black Console because the #'s have updated & changed.
Will you double check the 2346680 part number I think you may be 1 number short.
Is the number 23466980? I'm still trying to determine if there is anything different about the 16 console and wiring vs the ones that others have ordered for the 14-15. Does someone with a 16 console know if the media card slot still exists in the 16 model?
Edited by MWZotti
The console connector in the pic is from console #23466980. I ordered it for a 2014 Sierra a week ago. They sub in this #'d console for the #22995069 console I originally ordered. So, the only black one out there is #23466980. The other # ending in 5069 is discontinued.
Thanks.
Anyone know where the fuse is located for the Front Dash 12V Cig plug on a 2014 Sierra? That has the 110v plug & 12v plug beside it? I checked fuses under hood & none where blown, the small ones that is. The 12v plug is dead.
I believe the fuse for that is on the left side of the dash - you need to open the driver door and there are 6 clips holding the side of the dash on - I believe it is in the same spot as the suburban/tahoe
careful not to break those clips
Edited by jamesonjc
I've got a 15 gmc 2500hd slt with center jump seat early build .. bought a new take off center console from a 2015i gmc 2500hd.. with the wireless charger.. i looked up harnesses and it only shows 2 diff ones.. one with dvd and one w/o dvd.. does anyone know if this will plug into my truck or need to splice in other components. thanks and i did read every page over last 2 days lol...
thank you
Thanks JamesonJC.............I was just over looking it in the panel & finally found it, it's the 15a fuse in far upper right, one of those new square purple top fuse.
20160315_190102.jpg[/url]
You can install the newer GMC in lid charger from 2015/16 console. You will need the complete lid & charger. Wire it into the back 12v plug. It's got 3 wires, black is ground, multi colored is positive. You will not use the green. It will turn on with key & turn off with key this way.
my console had the charging lid and theres a wire hanging down underneath console is that the whole charger or do i need more?also where do i get the plug in connector for the merc switch and led light.. theres 2 connectors or plugs i need thanks
I've read through this thread as this is one of the mods I'd like to do. To date has anyone gotten every port to work correctly like OEM?
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
