Yes, somewhere. They are posted in the other thread that pertains to that as well. Ill search and post if I can find them.
I think its much better with the lighter interiors. I didnt mind the wood, but wood looks best with dark interiors, I think this with the lighter works best
^ do you have the part # for all them pieces? Looks great!
2014 GMC Sierra 1500 SLT
Added DDM Tuning 5000K HIDs and blacked out the front and back GMC emblems
Got the windows tinted
and went 4x4 in the shell parking lot ! GRRRRRR!!!!
But a little time and sand paper it looks a lot better.
Putty and paint make us what we aint! (and sand paper). Good job
This is my first honest attempt at vinyl wrap. It's nowhere near perfect, but by the end, besides it being dark out, I got way better at it. Here are some shots of when I picked my truck up and the in progress vinyl. Will give it another go possibly this weekend
Plasti dip rims
2014 Silverado 1500 LT V8 4x4 All-Star Edition
Nice. How many cans?
I can't see it in person, but from the pictures it looks like an incredible first attempt. If you wouldn't have posted the pic with the bumper being chrome, I would've been fooled into thinking the bumper was factory painted. Also, if I were you, I would give a crack at doing the air damn. See how it comes out. I think it would look good if you can get it on there properly
How did this work out for you?
Are they any brighter?
Same bulb for both cargo and backup?
4 bulbs total?
What about the center brake light?
I've been thinking about this because it looks inexpensive and easy and the stock back up are not very bright.
Worked out great..REAL bright!! Yes they're the same 921 bulbs for both. I didn't think about the center brake light and honestly don't know if it's the exact same bulb. Since it has a red lens I don't know if there'd be enough difference to mess with. But I recommend the others for sure.
4 bulbs total?
I used the same basic bulb except I got ones that were rated at 50W, they are very bright and much better than stock because of the white color and it is brighter than stock IMO. Also I found mine matched the color of the interior domes and the LED DRLs.
The 3rd brake light/center stop lamp, it is the same bulb, but I would recommend using a red bulb because if it is white then it may cause the light to look lighter than it should so it will look more pinkish than it is now.
These are "projector bulbs" (what ever that is). I guess 10W is enough for them. I don't see how anything could be that much brighter. I turned on the cargo lamp after I had installed one and left the stock one in to compare the two and the stock 921 actually looked brown next to the bright white LED. The backup lights are blinding in the dark too.
Here are a couple more in the daylight. The flaws are more obvious in these. I will look into removing the fog light deletes for my next try. I'm not so hot on doing the valence, I like the way it looks, but I do want to try doing a matte green plasti dip on the tow hook surround
Did you need load resisters to stop the missing light bub warning from displaying due to low current draw?
Do you have a link to the bulbs you used?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
