Yes, somewhere. They are posted in the other thread that pertains to that as well. Ill search and post if I can find them.
I think its much better with the lighter interiors. I didnt mind the wood, but wood looks best with dark interiors, I think this with the lighter works best
^ do you have the part # for all them pieces? Looks great!
2014 GMC Sierra 1500 SLT
Added DDM Tuning 5000K HIDs and blacked out the front and back GMC emblems
Got the windows tinted
and went 4x4 in the shell parking lot ! GRRRRRR!!!!
But a little time and sand paper it looks a lot better.
Putty and paint make us what we aint! (and sand paper). Good job
This is my first honest attempt at vinyl wrap. It's nowhere near perfect, but by the end, besides it being dark out, I got way better at it. Here are some shots of when I picked my truck up and the in progress vinyl. Will give it another go possibly this weekend
Plasti dip rims
2014 Silverado 1500 LT V8 4x4 All-Star Edition
Nice. How many cans?
I can't see it in person, but from the pictures it looks like an incredible first attempt. If you wouldn't have posted the pic with the bumper being chrome, I would've been fooled into thinking the bumper was factory painted. Also, if I were you, I would give a crack at doing the air damn. See how it comes out. I think it would look good if you can get it on there properly
How did this work out for you?
Are they any brighter?
Same bulb for both cargo and backup?
4 bulbs total?
What about the center brake light?
I've been thinking about this because it looks inexpensive and easy and the stock back up are not very bright.
Worked out great..REAL bright!! Yes they're the same 921 bulbs for both. I didn't think about the center brake light and honestly don't know if it's the exact same bulb. Since it has a red lens I don't know if there'd be enough difference to mess with. But I recommend the others for sure.
4 bulbs total?
I used the same basic bulb except I got ones that were rated at 50W, they are very bright and much better than stock because of the white color and it is brighter than stock IMO. Also I found mine matched the color of the interior domes and the LED DRLs.
The 3rd brake light/center stop lamp, it is the same bulb, but I would recommend using a red bulb because if it is white then it may cause the light to look lighter than it should so it will look more pinkish than it is now.
These are "projector bulbs" (what ever that is). I guess 10W is enough for them. I don't see how anything could be that much brighter. I turned on the cargo lamp after I had installed one and left the stock one in to compare the two and the stock 921 actually looked brown next to the bright white LED. The backup lights are blinding in the dark too.
Here are a couple more in the daylight. The flaws are more obvious in these. I will look into removing the fog light deletes for my next try. I'm not so hot on doing the valence, I like the way it looks, but I do want to try doing a matte green plasti dip on the tow hook surround
Did you need load resisters to stop the missing light bub warning from displaying due to low current draw?
Do you have a link to the bulbs you used?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
